6V6 line preamp
6V6 line preamp
Old 12th April 2013, 01:45 AM   #1731
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
See with 16k-32k bins so it can be fast, magnitude, Blackman Harris, dbV. It only does vertical log unfortunately so leave it to linear scale.
Old 12th April 2013, 01:59 AM   #1732
stajo is offline stajo  Sweden
6V6 line preamp
Seems like I can go up to 512 then it disappears
Old 12th April 2013, 02:05 AM   #1733
Salas's Avatar
6V6 line preamp
We already see portion of audio band at -92dbV DUT/instrument combined noise floor (0dbV=1VRMS), -72dBV hum at 50Hz. You only got a 100Hz portion though. There is a menu that selects bandwidth, and there is a generator menu that selects test frequency.
Old 12th April 2013, 02:14 AM   #1734
6V6 line preamp
I am very pleased with this. I have had the pleasure to learn instrumenting and measurments from master degree teacher.
I will continue my struggle, maybe I will ask you again. Thank you so much for your help Salas. You are the best, we (I) are a little slow sometimes.
We are here for the reason of getting and sharing knowledge. There is no better place.
Thx
Old 12th April 2013, 02:19 AM   #1735
Salas's Avatar
6V6 line preamp
I am not particularly good in instrumentation, those are just basics I learned myself. But very useful. There are many members here that are very good in such. Chris (Anatech) was very good in it when he was posting. Has many top gear.
Old 12th April 2013, 02:26 AM   #1736
6V6 line preamp
“If you can't explain it simply, you don't understand it well enough” Albert Einstein
and you can
Old 12th April 2013, 02:27 AM   #1737
Salas's Avatar
6V6 line preamp
Its because I did the Simplistic circuits.
Old 12th April 2013, 02:31 AM   #1738
6V6 line preamp
I know what knowledge means, in my areas
Dont be shy
Old 12th April 2013, 02:43 AM   #1739
Salas's Avatar
6V6 line preamp
A countryman of yours put it that way:
If I have a thousand ideas and only one turns out to be good, I am satisfied.
Alfred Nobel
Old 12th April 2013, 09:26 AM   #1740
6V6 line preamp
Alfred Nobel
Explosive stuff
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 09:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 05:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 05:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 05:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 04:11 PM
