6V6 line preamp
6V6 line preamp
Old 10th April 2013, 05:27 PM   #1641
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
Using AC coupling to the scope for all captures I guess. Looking early rounding in the HF. Showing the same for the grounded grid pre maybe shows a trend in the measurement loop. What is the wave generator spec? What is the probe spec and its setting?
Old 10th April 2013, 05:33 PM   #1642
stajo is offline stajo  Sweden
6V6 line preamp
Scope is set on AC for the measures. Does that matter since its after the output cap?
Its this Very-High-Resolution Oscilloscopes from Pico Technnology one and the built in signal generator. I havent used it much so mebbe i have some settings wrong.
Probes... well, the ones that came with. It says 60 mHz on them. Setting x1
Staffan
Old 10th April 2013, 05:55 PM   #1643
Salas's Avatar
6V6 line preamp
Oscilloscope — Vertical
Bandwidth
20 mV range
10 mV range 5 MHz
4 MHz
3 MHz
Bandwidth limiter 200 kHz, switchable
Rise time (calculated)
20 mV range
10 mV range 70 ns
88 ns
117 ns
Signal Generator
Standard output signals Sine, square, triangle, DC voltage, ramp, sinc, Gaussian, half–sine, white noise, PRBS
Standard signal frequency DC to 20 kHz
That last spec above means you should expect decent square up to 2kHz and its best rise time up to 1kHz only. Difficult to see wee HF wiggle if any is there with those rise times and bandwidths mentioned. But a low frequency one at 1kHz or under it should have been visible. AC coupling to a scope introduces further high pass but its not of interest here, avoid DC coupling in non HV CAT I capable mini scope interfaces inputs when probing valve gear. When a probe is set at X1 it drastically cuts its bandwidth spec to few MHZ but the system gains SNR is what happens. Still at much faster spec than the included generator, so its OK for that.
Old 10th April 2013, 06:02 PM   #1644
6V6 line preamp
I have a better (I think) signal generator somewhere that I might try tonight after i putted kiddo to bed. So I shall keep the other measurement settings?
Old 10th April 2013, 06:03 PM   #1645
Salas's Avatar
6V6 line preamp
P.S. That pico model looks good enough for audio band FFT though.
Old 10th April 2013, 06:05 PM   #1646
Salas's Avatar
6V6 line preamp
If its cheap DDS it will have wiggles of its own on square waves. See if it can output 10-20kHz good squares as a loop to the scope first. Optimize any settings needed. If it can, then introduce the devices under test in the loop.
Old 10th April 2013, 07:55 PM   #1647
6V6 line preamp
You were surely right about the built in signal generators limitations up in the freq ranges. Heres some pix of that: 10kHz and 20kHz
Old 10th April 2013, 07:57 PM   #1648
6V6 line preamp
And heres an old Wavetek model 182 that can do the squares but with some nice wiggles
Old 10th April 2013, 07:59 PM   #1649
6V6 line preamp
Heres the GG with Wavetek, 10kHz, 15kHz and 20kHz (same as above):
Old 10th April 2013, 08:00 PM   #1650
6V6 line preamp
And the patient itself, same freqs:
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
