6V6 line preamp
6V6 line preamp
Old 22nd March 2013, 10:45 PM   #1581
iko is offline iko  Canada
iko's Avatar
6V6 line preamp
Interesting! Maybe I'll give it a try.
Old 23rd March 2013, 12:10 AM   #1582
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
6V6 line preamp
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 23rd March 2013, 08:22 AM   #1583
stajo is offline stajo  Sweden
6V6 line preamp
Originally Posted by vgeorge View Post
B+ 295V now, at 16,5 mA.
What is your bias for that?
Old 23rd March 2013, 08:57 AM   #1584
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
6V6 line preamp
I have 12,3V across the 750R cathode resistor.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 23rd March 2013, 09:31 AM   #1585
6V6 line preamp
So your anode voltage is about 183 in idle?
Old 23rd March 2013, 09:38 AM   #1586
vgeorge's Avatar
6V6 line preamp
Correct.
I know not optimum, but the only way to up the voltage would be to get a new rectifier tube.
I tested it with a sovtek 5ar4 and got 15V on the cathode with 330V B+, 220V on the anode.
Unfortunately, I use this for my power amp.
Old 23rd March 2013, 09:52 AM   #1587
6V6 line preamp
It is very hard to see on schematics because the 6V6 in this application is working so low compared to its capacity and normal operating area that it is almost impossible to judge from the loadline on paper. But your measures on the scope shows good results.
I wonder how Salas came up with this idea, cause its a bit odd but showes good results.
At this currents a 1660 gaped for 18 mA (wich I happen to have somewhere) would be happy.
Old 23rd March 2013, 09:55 AM   #1588
vgeorge's Avatar
6V6 line preamp
I am going to listen soon at 20mA and report if there is a difference.
I would be very interested for your opinion if you try the LL1660 here.
Old 23rd March 2013, 11:34 AM   #1589
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
The blue rectangle point is what George has now. The red point is what we use when B+ is plenty. When assuming that the reissue tubes are staying roughly on that old GE map of course. Each valve is consuming 3W when on the blue, 4W when on the red. We go a little >200V >4W usually for the red, but I centered it for clarity.
Old 23rd March 2013, 11:45 AM   #1590
6V6 line preamp
And heres Georges approximate loadline. I put some marks around where the tube operates with 2 V RMS in.
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 09:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 05:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 05:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 05:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 04:11 PM
