6V6 line preamp
6V6 line preamp
Old 22nd March 2013, 03:49 PM   #1561
iko is offline iko  Canada
iko's Avatar
6V6 line preamp
Nope, my 26 has a ixcp10m90s gyrator load and cap output. No cash for a good output transformer.
Old 22nd March 2013, 03:57 PM   #1562
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
I am sure it measures much better that way.
Old 22nd March 2013, 04:08 PM   #1563
stajo is offline stajo  Sweden
6V6 line preamp
Well sqarewaves are squarewaves and music is music. Squarewaves are good for tracking problems, not so good for judging the goods or bads in a music machine. No news for anyone here I guess.
Vgeorge, I wouldnt be surpriced is the 25 mA iron is on the edge of saturating, and that might be what we are looking at.
There is lots of line trafos that leaves unnoticable footprints on squarewaves, I think its more of an implementation thing.
Old 22nd March 2013, 04:12 PM   #1564
Salas's Avatar
6V6 line preamp
Still the wiggle was no accident, it denoted resonance that manifested in excess microphony. Choke load takes double the Ip spec and a snubber it seems so to be judged correctly. It owes to bring less THD and more gain to the plate but in a behaving manner.
Old 22nd March 2013, 04:20 PM   #1565
6V6 line preamp
Amen to that. I merely ment that one shouldnt diss iron as a concept based on a single implementation.
Old 22nd March 2013, 05:19 PM   #1566
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
6V6 line preamp
Correct Stajo. I don't dismiss iron, in fact I try to use it most possible. Just this iron in this implementation did not work out. In fact in my power amp I m using now have some nice Hashimotos!
Even if I solved the slight ringing on the scope, I should take extreme measures to avoid microphonies.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 22nd March 2013, 05:22 PM   #1567
vgeorge's Avatar
6V6 line preamp
If your power amp has a highish input impedance that' s fine!
Old 22nd March 2013, 07:49 PM   #1568
vgeorge's Avatar
6V6 line preamp
I found some Mills 6,8K resistors and put them in.
Plays beautifully now! Excellent sound, I m thrilled!
I will get a stronger subchassis for the parts and rearrange things a bit in the future, now that I do not use the chokes.
Old 22nd March 2013, 07:53 PM   #1569
iko's Avatar
6V6 line preamp
Seriously, the two resistors made a difference in sound?
Old 22nd March 2013, 08:11 PM   #1570
vgeorge's Avatar
6V6 line preamp
They were better suited to this circuit compared with the chokes I used. Maybe other chokes would perform better. Resistors were less prone to pick up vibrations mainly, that resulted in clearer sound. Still need work t do on the chassis as I said.
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
