6V6 line preamp
6V6 line preamp
Old 22nd March 2013, 09:43 AM   #1541
stajo is offline stajo  Sweden
6V6 line preamp
It can surely have helped. Isolating vibrations can be counted but its very hard so I usually do trial/error. With bad luck you can enhance microphony if you happen to pick the self frequency regarding to weight and isolation material.
Old 22nd March 2013, 10:06 AM   #1542
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
Mesh construction breaks resonance. That is why they made such plates on best DHT power valves versions. Just tap on a window mesh frame. Mute thump-thump.
Old 22nd March 2013, 02:09 PM   #1543
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
6V6 line preamp
Ok, here are the latest findings.
Shaking or taping the box, doesn' t change a thing.
I replaced the choke in one channel with 2X11k resistors in parallel the square wave is perfect.
I am listening what the experts have to say now!
Should I remove the chokes?
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 22nd March 2013, 02:14 PM   #1544
Salas's Avatar
6V6 line preamp
Its the choke then, what else. Chokes have habits it proves. Stajo, go knock at Lundahl's door next time you are about, and tell them "I got a friend with a wiggle, have you got a remedy?".
Old 22nd March 2013, 02:15 PM   #1545
Salas's Avatar
6V6 line preamp
Listen to both R Load and Choke load. The <1kHz sq wave wiggle may prove an insignificant thing when the loading does many other very important things.
Old 22nd March 2013, 02:18 PM   #1546
vgeorge's Avatar
6V6 line preamp
Originally Posted by Salas View Post
Its the choke then, what else. Chokes have habits it proves. Stajo, go knock at Lundhal's door next time you are about, and tell them "I got a friend with a wiggle, have you got a remedy?".
This is nothing compared to LL1660 measured response....
Old 22nd March 2013, 02:18 PM   #1547
vgeorge's Avatar
6V6 line preamp
Will do some tests and see then. Easy to try.
Old 22nd March 2013, 02:19 PM   #1548
6V6 line preamp
I can do the underpants grip on him next time, Im about to rip him off some 50 mA 1668s sooner or later. Hey, try some pF-nF caps mr Poros, you might find the resonance.
Old 22nd March 2013, 02:21 PM   #1549
vgeorge's Avatar
6V6 line preamp
Ok, will try that too.
Old 22nd March 2013, 02:24 PM   #1550
6V6 line preamp
Found the bestards. Heres what you should use.
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
