6V6 line preamp
6V6 line preamp
Old 21st March 2013, 07:22 PM   #1511
stajo is offline stajo  Sweden
6V6 line preamp
Originally Posted by Salas View Post
We are team chasing the elusive wiggle. Nice, I like it.
When Im done with my CF Im gonna take it as hand-baggage down to Poros, ok?
Old 21st March 2013, 07:27 PM   #1512
Siberia is offline Siberia  Lithuania
Siberia's Avatar
You won't get the real time waveform update..,
Convinced, calm and ready to splash on analogue. Happy wiggle hunt, guys.
Old 21st March 2013, 07:45 PM   #1513
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
6V6 line preamp
You are welcome any time, especially with nice hand-baggages!
I tried with carbon resistor, no change.
Regarding OPT, the LL1660 does have some nice ringing in the 50kHz region in my #26. After that, these chokes look nice!
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 21st March 2013, 07:51 PM   #1514
SGregory is offline SGregory  United States
I calculate that the freq of the ring is between 8333 hz or 10,000Hz. Assuming I read the picture right with 0.2mSec/div. I also think that if it were a signal riding on the output, it would not decay. Could be wrong though. A FFT would be interesting here.
Living Life Doing the Waltz in 4/4 meter.
Old 21st March 2013, 08:24 PM   #1515
vgeorge's Avatar
6V6 line preamp
The square on the picture is 1kHz.
The probe is 10x.
A FFT, good idea. Never done that, maybe should try and learn how to do it.
It' s getting cold tomorrow....
Old 21st March 2013, 08:40 PM   #1516
I calculated using the second picture on post #1490. I got 500Hz for the square wave
Old 21st March 2013, 09:03 PM   #1517
vgeorge's Avatar
6V6 line preamp
You are right, I did not understand about which picture you were talking.
Old 21st March 2013, 09:30 PM   #1518
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
Few kHz is very low to be some typical oscillation on the other hand. Puzzling. Could be those anode chokes have a characteristic resonance frequency?
Old 21st March 2013, 09:35 PM   #1519
That is what I was thinking. I feel it is a resonance based on the decay, but freq is pretty low. Also note that leading edge of square wave is pretty clean. Would be interesting to see what elimination of cathode bypass cap would bring on the 500Hz square wave
Old 21st March 2013, 09:43 PM   #1520
6V6 line preamp
My memory is weak but I think I asked before. What current are we currently talking about? And whats the spec on the choke? Per Lundahl can easily give you the spec for the task. Expressed in tesla for everyones convenience
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
