6V6 line preamp
6V6 line preamp
Old 14th March 2013, 12:00 PM   #1461
stajo is offline stajo  Sweden
6V6 line preamp
Originally Posted by Salas View Post
Yes, but they have something in common, they both can smoke without warning.
No biggie. I can do that too
Old 14th March 2013, 12:02 PM   #1462
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
Well, we momentarily forgot about Stajo brand. Apologies.
Old 14th March 2013, 12:16 PM   #1463
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Here is legit question...I think. Some folks say that you want your pre doing most of the gain, getting signal out of the dirt, others say, why throw away so much gain, if it is not needed. I will have very efficient system, so which is better?
...Shape the sound , Man!
Old 14th March 2013, 12:25 PM   #1464
6V6 line preamp
There is no gain in more gain then you need
But surely, its better to have most gain where you have a fairly disturbance free surrounding. High gain in the first stages of a power amp for example can easily be affected by a badass trafo for example. The gain needed in your pre is predicted by the sensitivity of your Fujiyama, imho.
Staffan
Old 14th March 2013, 12:28 PM   #1465
Salas's Avatar
6V6 line preamp
Read Pano's gainstructure article.
Old 14th March 2013, 12:36 PM   #1466
buzzforb's Avatar
ah. Forgot about that one. DOnt be talking about my mountain, Stajo.
Old 14th March 2013, 01:08 PM   #1467
6V6 line preamp
http://www.diyaudio.com/forums/diyau...structure.html
Old 14th March 2013, 01:52 PM   #1468
6L6 is offline 6L6  United States
6L6's Avatar
6V6 line preamp
Originally Posted by harlee View Post
Just for the record, I used 2 point grounding like Sakuma. Absolutely no audible hum, at least in my system.
Sakuma was talking the same thing as American engineers call bus bar grounding?
Very similar - see here: Inside Sakuma Amplifier
(Yes, this is from an old post, but I was re-reading this thread and thought you would like to see the link.)
Old 14th March 2013, 02:07 PM   #1469
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
6V6 line preamp
In my build where they are standing near the bottom cover and the 317 sink they get hot and I did not trust 2W. In George's that the box has height and the 317s dissipate at an angle on a large plate maybe 2W they would suffice. After long time some of my tubes tended to give more heater emission and I adjusted them to 20Ω//3.3Ω finally. So even my happier tubes don't overheat. Thermals and voltages are to be checked and adjusted if necessary in individual builds of course. Even another LM317 brand can have a bit different Vref etc.
To get the correct voltage I had to use 20R//3.3R//39-47R MF 0.5W depending on the tube.
Regarding the cement resistors, this is what I had in my stash now. Hope they won' t hurt the sound.
Also I lifted the heaters to around 45V.
In fact I built this amp with everything I had on hand already. I only bought the tubes.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 14th March 2013, 02:13 PM   #1470
vgeorge's Avatar
6V6 line preamp
Originally Posted by buzzforb View Post
Fukushima?
Vgeorge, I want th elow down on your Speakers. I have some Altec 416's and 288's sitting here waiting on boxes. I was going to put the 416's in a large Ml-TWQT, showing pretty flat response down to 35, with nic slow taper. I am afraid I dont have the rrom for true bass horns like yours. The 18's look like they are from AE.
Buzz, I am using a combination of horn bass reflex from 80Hz to about 700Hz.
Regarding your 416, the thing is how well they are going to integrate with the horn and at what sensitivity, if you plan to use only one amplifier. With what horn are you planing to use your 288 with? For bass they are TD15X from Lambda, before they were taken over by AE. The box is big because I already had it and had the room for it. My plan is to integrate with the main speakers sometime in the future.
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 09:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 05:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 05:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 05:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 04:11 PM
