6V6 line preamp - Page 143 - diyAudio
Old 27th January 2013, 11:45 PM   #1421
Originally Posted by Salas View Post
Good looks. Did you take any anti microphonic measures? Its the common cathode 15dB gain circuit yes?
My 6V6 preamp does'nt have much microphonic like my 71A preamp, so I have not to get anti microphonic treatment.
I increase grid stop Res to 3.3K, so noise is a bit lower
I don't understand much your mean about "common cathode 15dB gain circuit".
Old 28th January 2013, 12:55 AM   #1422
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
I mean the classic one 6V6 preamp that has gain, not the cathode follower buffer version a few make. If you swap your 6V6 bottles between channels does the hissier channel change? Is it you got one hissier tube or some difference in PSU, layout, that maybe creates one a noisier channel?
Old 28th January 2013, 02:50 AM   #1423
One 6V6 is hissier than other one when I swap them each other .
I don't like cathode follower buffer, I feel its sound become rigid, not more magic . So I like choosing the tube with low resistance for this place or using step down OPT.
Old 28th January 2013, 10:29 AM   #1424
Salas's Avatar
This one is making not that rigid a buffer, its nice as far as CFs go. And about 220 Ohm output impedance. Its a matter of synergy in a system also, blending tone. Anyway the gaining pre is the main theme here, CF is a spin off. Have you got any close up and inside pictures of the construction? People may like to see for ideas. Happy listening!
Old 28th January 2013, 11:40 PM   #1425
If you have pre with some gains, you can design power amp with only 1 stage of amplification. This preamp has almost 6V out.
Low output impedance is good. This preamp has nearly 1.5K, not bad so far
inside photo ? sorry, I did build this one for my friend and I sent to him . But, I will draw the detailed schema as soon as possible.
Old 29th January 2013, 01:34 AM   #1426
j45yip is offline j45yip  Singapore
hi tcqanh, what's your view on this 6v6 pre connected via a step-down line optx? i need a low output impedance as my pre will be driving 2 power amps. don't like the CF approach as well
Old 29th January 2013, 01:55 AM   #1427
Step down OPT is always good for output. But the problem is just its quality. Higher ratio is worse quality cause of parasite Capacitance and Fe material.
I like 5K- 600 ohms OPT for preampli, with this one you can make a preamp to many tubes that have internal resistance 1-2.5K. 6V6, 5687, 12BH7, 6C45P... are examples.
Note that how much DC max current can OPT get ? In my experience, you can take your opt run 1/2-2/3 max currrent. ex, opt can get max 20mA from data's manufacturer, you should run 10mA.
Old 8th March 2013, 12:32 PM   #1428
stajo is offline stajo  Sweden
Just a quick update here. I whined over hum last time which was pretty childish of since I obviously cant build a proper PSU. I just putted something together that looks like any other preamp PSU i have done b4. I forgot to put in the fact that this pre takes more then 5 times more current that a normal one. As I had the scope up is measured almost 350 mV ripple on B+. The waves was exactly 20 ms (50 Hz) so there was not much to say. Unsufficient filtering.
So I got violent and squeezed in 2 old tube radio OPTs instead of the former 6K8 resistor.
Theyr about 11-12 H each on the primary and serves one channel each.
Ripple went down to around 2 mV which I can hear on my 99 dB speakers, but then I have to have ny ear in the cone. Otherwise I dared to play half a song and it rocked. I didnt want to shockride it to much since I had some 360 volts on the anodes.
So, there is hope.
And then I spoke to mr Per Lundahl today and he is more then happy to make me some http://www.lundahl.se/pdf/1667_68.pdf special gapped to 50 mA. I think a DCR of 680 is to prefer over my Hinchleys almost 1 k.
I will tweak on and listen some more before I decide.
cheers
Staffan
Old 8th March 2013, 12:35 PM   #1429
iko is offline iko  Canada
iko's Avatar
Don't be so quick to blame it on the psu. 50Hz/60Hz hum can be the result of wiring or component location (near transformer) or transformer orientation. The grounding scheme makes a huge difference as well.
Old 8th March 2013, 12:45 PM   #1430
Your right Iko. I was refering to that I thought it was oscillation between the chokes and the output caps, wich would have been more irritating.
The measure above is from spagetti cabling, everything unshielded and with iron tweaked in here and there as you see. I can clearly just get better with some proper layout work.
best regards
Staffan
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
Copyright 1999-2017 diyAudio
