6V6 line preamp
6V6 line preamp
Old 26th January 2013, 06:32 PM   #1411
buzzforb is offline buzzforb  United States
buzzforb's Avatar
DCb1 is no slouch by any measure. It is my SS volume control. If you dont need the gain, try the CF. It will be next for me. I will have both versions interchangable, depedning on my mood.
...Shape the sound , Man!
Old 26th January 2013, 06:35 PM   #1412
RCruz is online now RCruz  Switzerland
nhinstruments
RCruz's Avatar
6V6 line preamp
CF?
RC
Old 26th January 2013, 06:40 PM   #1413
buzzforb's Avatar
cathode follower. It is on first page. Would be good alternative to DCB1 if no gain is needed. Check first page.
Old 26th January 2013, 07:43 PM   #1414
nhinstruments
RCruz's Avatar
6V6 line preamp
Thank you.
I know it is a good contender... that is why I am following.... It will happen soon
RC
Old 26th January 2013, 09:23 PM   #1415
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
It pushed the B&W MPA 1 monoblocks I repaired very easily in CF mode today. Those are 30dB gain amps nonetheless. And I liked live voices on the radio too.
Old 26th January 2013, 10:01 PM   #1416
stajo is offline stajo  Sweden
6V6 line preamp
Nice Salas. I had kids here today so it was more Minecrafting then soldering but I made those:
The hawkeyed can see that it has the same screwhole placement as SSHV2, so I can interchange them. The cap-thingy will become an R-C then.
I also did some quick voltage measurement and I ended up between 245 and 310 V B+ with 2,2-6,6 k as last R. That puts the bias to between 16,6 to 21 V which might put me in a strange little corner on the curves. Maybe a 680 DCR LL1660 would be more suitable.
Then I'm stuck with a strange groundnoice. I rewired stargrounding without results. DC-filaments and more smoothing C dont affect it.
Well, one's got to save some for the day after...
Staffan
Old 26th January 2013, 10:13 PM   #1417
Salas's Avatar
6V6 line preamp
Is there a possibility something oscillates there? What does the scope show?
Old 26th January 2013, 10:21 PM   #1418
6V6 line preamp
Thats possible. Usually that takes us to motorboating but i can easily swap the filterchoke to a resistor and see if it there. I could also rig the scope. Its downhill skiing on the agenda tomorrow so lets see what it brings.
I changed last RC and also second C a couple of times so it shouldnt be there . And its overkill 1 k carbons on the grids. But you never know with chokes and capacitors.
Old 26th January 2013, 10:32 PM   #1419
Salas's Avatar
6V6 line preamp
Can be some nuisance in the cathode circuit interfacing with the iron beasts.
Old 26th January 2013, 10:39 PM   #1420
6V6 line preamp
Well yes. I could check with a lil resistor network instead of beasts.
Cathode Circuit is currently just the chokes (930 DCR 100+ H), 10 uF output caps decoupled with 10 k to ground.
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
