#1381 | |
Its RCA Black anode matched. well I think I have some 2-3 hundrish 6V6es laying around. What do you suggest? I think Im gonna work me down on the current scale and skip the opt cap for a tranny instead. Theres some nicer tubes growing in 1000th around. I'll throw it to you if you catch ![]() /S Last edited by stajo; 24th January 2013 at 09:34 PM. |
#1382 |
diyAudio Chief Moderator
Staffan, nice. Sure its grounding and not rail ripple?
#1383 |
Mmm. Rail ripple is there. But also grounding and microphonics actually. I tried a double inversed 2007 to ground but it didnt match with my other equipment. This is a start for the feeling of sound. Impedance is the cruical thing for sounds in in pre's. I also do AC heating now. I will work it thru.
#1384 |
brummer to gnd , or elevate ?
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#1385 |
Brummer is to ground by 2 100 k to CT, I'll see if lift goes tomorrow. I like AC. Its also touchy sensitive so I'll have a look if i have a minute tomorrow.
#1386 | |
#1387 |
Its all very rough now, but as I like the sounds I will go down on it. OPT signal has long antenna wires. As usual I started with lowish C in the filters, usually it needs to be worked up in SE.
I will start measure the rail ripple tomorrow. But, as I said, in anode followers we usually try to filter the upper rail. But think about it, we have actually 2 rails, plus and gnd. And here we're taking signal from just above gnd rail. |
#1388 | |
#1389 | |
#1390 |
Mine was very quiet first go round. Not until i tried tube rectifier did i have trouble, but i am a greenhorn. I had to wipe off my tablet screen when i saw that tube collection. Mine are nos rca. Tungsol sounded good enough for me to warrant the cost. If Salas' RIAA imoresses like this pre, he will fill my entire chain, with the exception of the main amp.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
| Help me design my DAC/Line Preamp. | kuroguy | Tubes / Valves | 7 | 2nd April 2009 08:31 PM |
| preamp line ctt | richwalters | Tubes / Valves | 1 | 7th March 2008 04:34 PM |
| Preamp for Line In and Mic | blur | Instruments and Amps | 1 | 4th January 2007 04:02 PM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
| Line preamp for 2A3 amp | Petman | Tubes / Valves | 0 | 24th May 2002 03:11 PM |
