Old 6th January 2013, 10:12 AM   #1371
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
I had built with resistive load non bootstrap and bootstrap and I kept the latter with Teflon input. Its easy for anybody to make the configs and check preference in own system and taste anyway. Tnx for the virtual pots.
Old 6th January 2013, 10:32 AM   #1372
stajo is online now stajo  Sweden
LL1668 gapped 50 mA maybe http://www.lundahl.se/pdfs/datash/1667_68.pdf windings in series 100H 680 DCR
http://www.diyparadiso.com/price/transfo/LLchoke.htm
Old 6th January 2013, 11:05 AM   #1373
Hey Salas,
I donīt understand:
"with resistive load non bootstrap"
Can not work without severe distortion.
Stajo,
1668 was actually one of the std chokes I had in mind.
Old 6th January 2013, 11:33 AM   #1374
Salas's Avatar
It can at low bias current and highish amp load. At about -60dB THD for ~6VPP.
Old 6th January 2013, 11:40 AM   #1375
Heres the breadboarded circuit for starters. By an incident I already had it on my breadboard. Now letz see if I can warp up a PSU b4 the kids storm the barn. 115 H 950 DCR Hinchley chokes (robbed from Perka, Lars.
Staffan
Old 24th January 2013, 08:56 PM   #1376
Well I choosed to make a "livingroom proto" instead since I have kids running around. I'm always nervous mounting touchable HV stuff in the livingroom. I made it like a AZ1 - 30 uF motorrun - 10H - 50 uF motorrun common chassie and then I made some plates to fit for different configs.
First out is the 6V6 chokeloaded CF. It sticks a 2,2R and double 47 uF for each channel. Abour 255 on the anode.
It playes right now and it has a clearly stiffer bass then my former passive. Nice voices too but still a hum and some other disturbances. 99 dB speakers is not nice to me. I will clear up the hum and get back to you with some measurements once I get sober. It will happen any month now.
Best
Staffan
Old 24th January 2013, 09:03 PM   #1377
buzzforb's Avatar
My new speakers I'll be HE Altec based setup. In this situation is Cf recommeneded over standard. It will be driving variety is pass amps ranging from 15-20dB of gain.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 24th January 2013, 09:03 PM   #1378
Forgot to mention: its 115 H Hinchely chokes on the katode. About 930isch dcr if I remember correctly.
made roome for some VRs to or a SSHV2 maybe
/S
Old 24th January 2013, 09:12 PM   #1379
I think this is promising. Thing is that carefulness is needed around a clean ground to, since its a CF. I will up an LL common mode choke b4 anode and ground but I'm not that sure how to mount it in the C-L-C-L-C chain. What happen if I mount it between the last C-C? Can that cause grounding issues? Well, I'll try and find out
/S
Old 24th January 2013, 09:15 PM   #1380
buzzforb's Avatar
Those tubes look kinds smoky Did you compare to modern version yet?
Nice job, BTW.
I got these for my rebuild. Thinking about getting BudP to wind me some for the load
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
Copyright Đ1999-2013 diyAudio
