6V6 line preamp - Page 137 - diyAudio
Old 6th January 2013, 12:08 AM   #1361
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
why wasting good glass for CCS-es , when you can have them ,sandy, easier
whatever , in that case I was sorta limited with PSU , space and blahblah
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 6th January 2013, 12:21 AM   #1362
stajo is offline stajo  Sweden
Thats not teh issue ZM and you know it. The issue is that if ya load a 20 k demanding poweramp with a regular anodefollower you might win or you might loose. And you dont know it on forehand. That is because anode follower preamps tend to change their bias point to whatever load they take.
Constructing a decent preamp is harder then this, unless you want to spend the rest of your days in a callcenter. Im sure you know what I mean. I have C3G on my breadboard.
Kisses
Staffan
Old 6th January 2013, 12:25 AM   #1363
Zen Mod's Avatar
Originally Posted by stajo View Post
...... The issue is that if ya load a 20 k demanding poweramp with a regular anodefollower you might win or you might loose. .......
not disputing that
Old 6th January 2013, 10:14 AM   #1364
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Nice.
Old 6th January 2013, 10:37 AM   #1365
vgeorge is online now vgeorge  Greece
vgeorge's Avatar
Very nice!
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 6th January 2013, 10:44 AM   #1366
Indeed! What happens if you put a rock steady 250 on g2?
Old 6th January 2013, 10:46 AM   #1367
Hey Salas,
Why make such a unecessary overpopulated design with yet another sound-degrading cap at the input.
As Ug is high a CCS is enough with grid related to ground. If more swing is need, as the CCS-version clips at the negative side at maybe 10Vrms, a choke with suitable DCR should be used. If no standard choke is available, I guess Dave Slagle will easily build one. If one have a choke with lower DCR than needed only a small, added series-resistor is needed.
In my example Ia is 30mA and choke DCR 500ohm. 20H gives -3dB at 5Hz. I would go for 50H.
Old 6th January 2013, 10:51 AM   #1368
Salas's Avatar
Does 2dB worse THD.
Old 6th January 2013, 10:54 AM   #1369
Salas's Avatar
Originally Posted by revintage View Post
Hey Salas,
*I need pot.inc
I like the non BJT aided bootstrap subjectively, with Teflon cap I could not feel it bit more opaque.
Old 6th January 2013, 11:01 AM   #1370
Hey Salas,
* A Collection of Potentiometers
* Helmut Sennewald, 12/23/2003 V1.1
* Models:
* potentiometer old style LTSPICE potentiometer
* pot_lin k*x
* pot_pow x^k
* pot_plog exp(k*(1-x))
* pot_nlog exp(kx)
* pot_tab table(x)
* pot_piher_plog piecewise linear, datasheet
* pot_radiohm_plog piecewise linear, measured
* 1 ____ 1.0=wiper
* | | 3
* | |<---- wiper 0..1
* Rtap | | Tap
* 2 ____| 0.0=wiper
* RTOT = total resistance
* WIPER = ratio of travel of the wiper
* RTAP = reference resistance at wiper=Tap
* It is needed only for pot_plog, pot_nlog and pot_pow.
* RTAP is measured between pin-2 and wiper.
* TAP = ratio of travel when Rtap is reached
*--------------------- The Linear Potentiometer ---------------------
* 1.0 <----- 0.0
* |3
* __V__
* 1--|_____|--2
* o--R1-o-R2--o
.SUBCKT potentiometer 1 2 3
* Parameters: Rtot, wiper
.param w=limit(0.01m,wiper,0.99999)
R1 1 3 {Rtot*(1-w)}
R2 3 2 {Rtot*(w)}
.ENDS
.SUBCKT pot_lin 1 2 3
R1 1 3 {Rtot*(1-w)}
R2 3 2 {Rtot*(w)}
.ENDS
*------------- The Ideal Power Function Potentiometer ---------------
* It is interesting to know that the power log. curve is a
* good fit to so called "log"-potentiometers, because most of
* them have not true logarithm dependency in reality.
* 1.0 <----- 0.0
* |3
* __V__
* 1--|_____|--2
* o--R1-o-R2--o
* RTAP is resistance at travel TAP
* Example: Rtot=10k, R=1k @ 0.5 (half way)
* RTAP=1k, TAP=0.5
* RTAP and TAP define a point of the curve resistance versus ratio.
.SUBCKT pot_pow 1 2 3
* Parameters: Rtot, wiper, Rtap, Tap
.param pwrexp=ln(RTAP/RTOT)/ln(TAP)
.param ratio=w**pwrexp
R1 1 3 {Rtot*(1-ratio)}
R2 3 2 {Rtot*(ratio)}
.ENDS
*---------- The Ideal Positive Logarithm Potentiometer --------------
* 1.0 <----- 0.0
* |3
* __V__
* 1--|_____|--2
* o--R1-o-R2--o
* Example: Rtot=10k, R=1 @ 0.001
* RTAP=1, TAP=0.001
.SUBCKT pot_plog 1 2 3
.param pwrexp=ln(RTAP/RTOT)/(1-TAP)
.param ratio=exp(pwrexp*(1-w))
.ENDS
*---------- The Ideal Negative Logarithm Potentiometer -------------
* 1.0 <----- 0.0
* |3
* __V__
* 1--|_____|--2
* o--R1-o-R2--o
* Example: Rtot=10k, R=1 @ 0.999
* RTAP=1, TAP=0.999
.SUBCKT pot_nlog 1 2 3
.param pwrexp=ln(RTAP/RTOT)/(TAP)
.param ratio=exp(pwrexp*(w))
.ENDS
* ------------ The Arbtrary(Table) Potentiometer --------------------
* 1.0 <----- 0.0
* |3
* __V__
* 1--|_____|--2
* o--R1-o-R2--o
.SUBCKT pot_tab 1 2 3
.param ratio=TABLE(w, 0,0.01m, 0.1, 0.001, 0.2, 0.003, 0.3, 0.01,
+ 0.4, 0.05, 0.5, 0.1, 0.6, 0.2, 0.7, 0.35,
+ 0.8, 0.6, 0.9, 0.9, 0.95, 0.98, 1.0, 0.99999)
.ENDS
*---------- A Positive "Logarithm" Potentiometer from PIHER ---------
* PIHER shows three piecewise linear functions in their datasheet
* for the resistance dependenncy.
* 1.0 <----- 0.0
* |3
* __V__
* 1--|_____|--2
* o--R1-o-R2--o
.SUBCKT pot_piher_plog 1 2 3
.param ratio=TABLE(w, 0,0.01m, 0.05,0.01m, 0.33,0.04, 0.66,0.16,
+ 0.95,0.99, 1.0,0.99999)
.ENDS
*--------- A Positive "Logarithm" Potentiometer from RADIOHM. -------
* RADIOHM shows a smooth "logarithm/power" curve in the datasheet.
* My own measurements on a 100kOhm stero pot has shown that it
* consists of five piecwise linear sections.
* 1.0 <----- 0.0
* |3
* __V__
* 1--|_____|--2
* o--R1-o-R2--o
.SUBCKT pot_radiohm_plog 1 2 3
.param ratio=TABLE(w, 0,0.01m, 0.1,0.01m, 0.3,0.012, 0.42,0.047,
+ 0.52,0.105, 0.64,0.25, 0.95,0.99999, 1.0,0.99999)
.ENDS
For practical reasons I use pot_lin. Do you also need asy´s?
Off course you should avoid the sand-version! But not everyone can afford a good choke.
Still bootstrap with input cap has no meaning at all with the correct choke. Overpopulated ;-)!
About distortion noone need to worry as 2nd will be in the ballpark -90dB at a realistic 2Vrms input/output.
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 09:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 05:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 05:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 05:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 04:11 PM
Copyright ©1999-2017 diyAudio
