6V6 line preamp - Page 136 - diyAudio
Old 5th January 2013, 01:22 PM   #1351
stajo is offline stajo  Sweden
Originally Posted by Salas View Post
20mA is the preamp's bias current, CCS should be 40mA when using double SSHV2, or 60mA when using common.
Ok, that makes sense. Is anyone using single SSHV2? Does it take the current and what happens to the channel separation without finishing with separate LC/RC.
Staffan
Old 5th January 2013, 01:42 PM   #1352
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Least happens with 10mOhm reg impedance, still double mono is superior. DimZ build was single common configuration, a few pages back he posted a couple of photos.
Old 5th January 2013, 02:19 PM   #1353
buzzforb's Avatar
It takes >=50K amp to do this FFT. The resistive one holds spec (worse) down to 20K, and the buffer down to 5K. Good luck when making it.
Salas, Could you explain further? Are you saying that this is sim'd performance of this amp with choke and resistor is better or worse. Have considered getting some chokes just to try. Just got new power transformer so will be rebulding it all.
...Shape the sound , Man!
Old 5th January 2013, 03:16 PM   #1354
DimZ is offline DimZ  Greece
yeap, single reg for 2 channels, takes the current like a champ ...
set to 63mA and 340V output ...
some day I'll try double SSHV2 to see -or better hear- the difference ...
*just visited a friend, I took from him a pair of kenrad 6V6 coke bottle and borrowed 2 tube testers (many 6v6 and 26 tubes to test) ....
its gonna be a funny weekend ...
Old 5th January 2013, 03:37 PM   #1355
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Originally Posted by massimo View Post
No doubt!
Let us know how LC load performs vs RC. I'm quite confident it will be better sounding.
I am going to try with LC first. If I don' t like the result maybe try with RC, but I don' t think so.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 5th January 2013, 04:10 PM   #1356
Just a suggestion to avoid confusion. L is induction, R is resistance. LC and RC is low-pass circuits consisting an inductive resp. resistive load in series with a capacistance parallelled to ground, in audio concepts often used in filters, like smoothing B+ or i speaker filters to cut high frequences. Rp is tubes inner resistance, Ra is anode load. If La is a common term I dont know but it would make analogue sence? Or what shorts do you prefere guys? Bermuda? Just watched swede juniors loose the hockeyfinals against USA. Cheers!
Staffan
Old 5th January 2013, 09:49 PM   #1357
Salas's Avatar
Choke is better and it needs lighter amp load to maintain all the goodness in this instance. Not that it is a complete slouch at 20K output load, but see the difference to 50K that I had posted before in #1348.
Old 5th January 2013, 10:04 PM   #1358
Buzz, Salas is speaking in tounges here as you notice. Every constructor will. That is becaus how your eventual preamp will work is 100 % dependent of your load, ie the poweramp or whatever.
Sum shorts: By every anode loaded preamp you test it will sound completely, and I mean compleatly different, against your load, ie the power amp.
Some anode loaded preamps will just fail, or go out of band if you load it to heavily.
The safest preamps (the best imo) doesnt care about the load. That is cathode followers or XXX:x anode loaded OPT preamps.
To many times I have heard people say "This is my preamp" and when they come home it sux.
CFs is hard to construct, very demanding and OPTs are expensive thats why.
Salas products are the best, no kidding, the very best. But you have to take the context in abbreviation.
Staffan
Old 5th January 2013, 10:40 PM   #1359
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
'xample of moderately decent CF ( all kudos to late AW , and boyz from Tek & HP)
Germanium Amp
third (right) pic
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 6th January 2013, 12:06 AM   #1360
Germanium Amp
third (right) pic
Yes ZM, im sure you could land any triode into a decent CF with enough steering. I think you could do it without sand tho, you just have to use the penthodes capabilitys. In laboration...
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 09:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 05:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 05:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 05:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 04:11 PM
Copyright 1999-2017 diyAudio
