6V6 line preamp - Page 131 - diyAudio
Old 28th December 2012, 03:37 PM   #1301
DimZ is offline DimZ  Greece
will do that ...
I have 10k and 20k (from the cheap ones) that I intent to try ...
Old 28th December 2012, 03:40 PM   #1302
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Those cheap ones are nice, they just don't last long and are not best transparency, yet still clean enough. But they show the way, and the channel balance is right. Before 40ish positions no switch pot is really smooth in volume handling is another thing they lack VS best.
Old 28th December 2012, 03:44 PM   #1303
exactly as you said, the show the way ...
best to start and experiment and quite decent sound quality,
as for durability I havent use any of them for more than 40-50 hours so I wouldnt know ...
Old 28th December 2012, 03:47 PM   #1304
thinking of puting a cover for safety reasons , a plexy maybe ....
its gonna be a long time playing with caps-tube-pots etc before I put it in a decent permanent alu box ...
Old 28th December 2012, 03:49 PM   #1305
Salas's Avatar
Do you have some elastic decoupling on the rods that the tubes support alu plate is mounted on?
Old 28th December 2012, 03:53 PM   #1306
yes, searching for the link ....
Old 28th December 2012, 03:57 PM   #1307
found it,
I use these
4x Anti Vibration Damper Isolator for FPV Aerial Photography GIMBAL ECILOP XA650 | eBay
but there also some more expensive (including shiping costs) ones here
PB Fastener Gewindepuffer 110004 Außen-/Außengewinde Schwarz im Conrad Online Shop | 546346
Old 28th December 2012, 04:00 PM   #1308
they seem to do a fine job,
I have to strike the alu plate quite hard to hear something from the speakers ...
Old 28th December 2012, 04:06 PM   #1309
Salas's Avatar
Well done. They look like working as the silencers they mount for aircon pump units on brackets.
Old 28th December 2012, 04:10 PM   #1310
quite flexible .... I think that if you dont screw them tight they wont work as they can, they must be a little tight ...
between screws its all rubber ..
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
Copyright ©1999-2017 diyAudio
