6V6 line preamp
6V6 line preamp
Old 28th December 2012, 02:40 PM   #1291
DimZ is offline DimZ  Greece
setup is netbook/foobar/m2tech/buffaloII/6v6 ....
with my 2.5 way 92db speakers (horns moved to another room for the holidays) ...
I listened it with zenV4 and f5, with both it sounded excellent, esp with zen cause zen needs the extra dbs (I was listening to it with dcb1) ...
Nick ... thank you for your design and for the unique power supply and all the members who contributed to it ....
now its time to play with some rectifier tubes and output caps ...
Old 28th December 2012, 02:48 PM   #1292
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
Looks good. What is the rest of the system?
P.S. Ok we cross posted, you are welcome.
Old 28th December 2012, 02:51 PM   #1293
Salas's Avatar
6V6 line preamp
Using a 50K pot?
Old 28th December 2012, 02:54 PM   #1294
I listen to flac's from a netbook (mostly 192/24), using foobar and hiface m2tech, then is the bufalloII dac ...
I havent listen through my cd player yet, and I dont have a turntable (tho I have about 500 vinyl records ....)
main speakers are 2w , with deltalite 2510ii in mltl and bc de250 in tractrix horns / x-over based on zilch's econowave work , for the holidays I have taken them to another room and I am using my artemis
yes I use a 50k pot, placed in the middle is allready too loud ....
Old 28th December 2012, 03:14 PM   #1295
Salas's Avatar
6V6 line preamp
Is it easy to push the column speaker for slam with a Zen or an F5? I guess that the line gain came up handy.
Old 28th December 2012, 03:21 PM   #1296
yeap !
they are 91-92db, so the gain was much appreciated ..
the horns are 95-96db ... still some extra gain will be nice to have there too ....
Old 28th December 2012, 03:26 PM   #1297
Salas's Avatar
6V6 line preamp
With such low gain main amps yes, gain aids their dynamics even on sensitive speakers. There was a very easy to understand article by member Pano about gain distribution in the whole chain. A rather underestimated thing in home audio but every one involved in live and recording systems knows its of cornerstone importance.
Old 28th December 2012, 03:28 PM   #1298
Salas's Avatar
6V6 line preamp
*Here is the link: http://www.diyaudio.com/forums/diyau...structure.html
Old 28th December 2012, 03:30 PM   #1299
yes, I have read that article, not long ago ...
btw pot is a cheap one, have tried it in dcb1 and it was fine for the job to start wth, later I replaced it with a khozmo one which was much much better of course ...
I probably put a khozmo in this line stage too - with z-foils this time ....
Old 28th December 2012, 03:35 PM   #1300
Salas's Avatar
6V6 line preamp
Khozmo has 25K too, hmm, could you try with 20-25K too to know what value you like best in your system and sources so to buy optimally when you will splash out for a posh pot?
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
