#1281 |
I'll check this later and report back ...
#1282 |
diyAudio Chief Moderator
Your DC conditions look spot on by the way.
#1283 |
dmm at DCmV with probes touching = zero ..
removed the teflon cap, no difference ... still variable indication at the DCmV position .. guess I have to recheck the rca's/pot grounding scheme ... which is pretty much as the one at post #1064 Last edited by DimZ; 26th December 2012 at 06:10 PM. |
#1284 |
Some DC settling during first minutes reflecting to the output caps when not connected to lower load as a main amp probably. Mine does the same. No worries I guess. Watch it over a 50 to 100K pseudo output load simulating an amp over 15 mins.
#1285 |
it is strange that it is constantly changing though ...
tomorrow I'll give it a try with a gc and some cheap speakers ... |
#1286 |
It would take a scope to make sure there is no waveform, but the norm is to go up and then go low over some minutes if it is just reflecting a DC drift as the various circuit blocks and supply warm up and settle.
#1287 |
if testing with amp-speakers wont work I'll take it to someone with proper instruments to work this out ..
#1288 |
I am not easily worried there is much chance its about something peculiar, its a non loop feedback very simple circuit to do particular funnies. With electronics and various layouts you never know on the other hand, but no, slim chance.
#1289 |
oops .....
it seems that when I changed the sockets and resoldered the parts yesterday I took the output before the 5k anode reistor and not after ... ![]() will fix that tomorrow ... Last edited by DimZ; 26th December 2012 at 06:51 PM. |
#1290 |
false alarm, the output was after the resistor ...
so, I took off the pot and done the wiring again ... and ... bingo !!! ![]() it's dead quite and it sounds wonderful ... |
| Help me design my DAC/Line Preamp. | kuroguy | Tubes / Valves | 7 | 2nd April 2009 08:31 PM |
| preamp line ctt | richwalters | Tubes / Valves | 1 | 7th March 2008 04:34 PM |
| Preamp for Line In and Mic | blur | Instruments and Amps | 1 | 4th January 2007 04:02 PM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
| Line preamp for 2A3 amp | Petman | Tubes / Valves | 0 | 24th May 2002 03:11 PM |
