#1191 |
each SSHV2 needs 20mA to operate properly ...
you must add it up .... Last edited by DimZ; 1st December 2012 at 08:02 AM. |
#1192 | |
thank you |
#1193 |
yes thats correct, though I dont know if there is any benefit of operating the regulator at 50mA , manual says 20mA is enough ...
you can find it here (first post by Teabag) GB for Salas SSHV2 regulator |
#1195 |
diyAudio Chief Moderator
Good luck Dim.
#1196 |
thanks ....
#1197 |
little progress so far,
done some woodworking, finished the SSHV2 and one filament supply ... I think theres not enough space, which layout seems better ? other options ? |
#1198 |
Better not have the laminations of that big power transformer face the 6V6, it is a Beam Power Tube...
#1199 |
It seems you are a perfectionist.... following your work with the utmost interest.
RC |
#1200 |
it may stay on this wood for some time,
as there are children around the house it must be at least tidy ... |
| Help me design my DAC/Line Preamp. | kuroguy | Tubes / Valves | 7 | 2nd April 2009 08:31 PM |
| preamp line ctt | richwalters | Tubes / Valves | 1 | 7th March 2008 04:34 PM |
| Preamp for Line In and Mic | blur | Instruments and Amps | 1 | 4th January 2007 04:02 PM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
| Line preamp for 2A3 amp | Petman | Tubes / Valves | 0 | 24th May 2002 03:11 PM |
