6V6 line preamp 6V6 line preamp - Page 118 - diyAudio
6V6 line preamp
6V6 line preamp
Old 3rd November 2012, 08:52 PM   #1171
cjkpkg is offline cjkpkg  United States
OK,
FINALLY have had a chance to finish this pre correctly...sort of...
Running a broskie PS-3 - SS B+ and regulated SS heaters.
B+ is 330
Cathodes see 15V
Kiwame resistors
Silmic cathode cap
Russian 6П6С
All values per schematic
I look forward to giving this some serious listening. I have reverted back hard to the Aikido but this pre now shows promise...I think that it is just as quiet as the aikdio...this is impressive to me.
Old 3rd November 2012, 10:10 PM   #1172
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
Congratulations. Drop as a note as to what you have learned after some run in.
Old 5th November 2012, 05:34 PM   #1173
Well as it turns out in switching around my sources that when I am using my satellite TV as the source - music channels - I have a faint buzzz. Not like before but there just the same.
Turntable? - no buzzz
Ipod? - no buzzz
Satellite? buzzzzzzzzzzzz
The turntable and the ipod are absolutely dead silent.
So this leads me to addressing the satellite input. Basically i have a homemade cable which runs about 30 feet from where the satellite receiver is to the other room where the amps are. This long run of cable must be the culprit. Step 1 was initiated today in the form of a pair of Edcor matching transformers. As much as I would have like some Jensen iron here I could not justify spending upwards of $200 when the Edcors are $10 each. Certainly worth a try to see if the buzz is tamed at all or for good.
Depending on the result I may splurge for the Jensens.
Old 5th November 2012, 05:38 PM   #1174
stajo is offline stajo  Sweden
6V6 line preamp
Ipod? - no buzzz
Try a ground isolator on the tv signal cable.
/Staffan
Old 27th November 2012, 08:25 PM   #1175
6L6 is offline 6L6  United States
6L6's Avatar
6V6 line preamp
Hello again!
My project has been on hold awaiting a SSHV2 group buy... It is done, and I have my shunt regulator. Hooray!
Does anybody have any specific information as how to implement it into this 6V6 circuit?
Thanks in advance!
Old 27th November 2012, 08:28 PM   #1176
buzzforb is offline buzzforb  United States
buzzforb's Avatar
It was a breeze. Well, not really. At first I had my tubes singing, but switched snsing wires to correct palce and worked fine. That was using my home etched PCB and not quality made board. You will love it.
...Shape the sound , Man!
Old 27th November 2012, 10:42 PM   #1177
6L6's Avatar
6V6 line preamp
I'm still confused how to set up the regulator... But I'm sure it will be awesome.
Ok, how much heatsink does it need? Can I use the top plate of the chassis or should it have a real heatsink?
Old 27th November 2012, 11:26 PM   #1178
buzzforb's Avatar
It needs a real heatsink, although the transistors used are tough. If you haev the boards, just get the type that is shown in as tall a format as possible. You can build it up a section at a time, testing as you go. PM if you need help. I make really nice smoke
Old 28th November 2012, 12:00 AM   #1179
6L6's Avatar
6V6 line preamp
I have stuff on hand, I'm just trying to plan for layout of the preamp chassis. I'm going to make a stand with this design and do it right.
Old 28th November 2012, 12:05 AM   #1180
buzzforb's Avatar
I think biggest heatsink you can get that fits the board profile is 2.5" tall. Wakefield or Ohmite
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
Copyright ©1999-2017 diyAudio
