#1161 |
OK thanks.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#1162 | |
diyAudio Chief Moderator
#1163 |
Yes, I did try it. If I recall correctly, it was a similar perception. Kind of dull, or missing the life. Hard to describe exactly. In truth none sounded really bad, just prefered the AC set-up better.
Living Life Doing the Waltz in 4/4 meter. |
#1164 |
Is there there a bit different harmonic content in THD measurement when with AC heating?
#1165 |
This is what I have. I don't recall why I stopped testing it as I don't really like the trash that I see with the 60Hz harmonics. I know I had a significant reduction in 60,120,and 180Hz with DC.
Regarding the 1kHz signal and harmonics, virtually identical or at least no difference I could see. +/- 1 or 2dB I recorded this almost a year ago, 30Dec11, so I am a little sketchy on all the details, but I know I had better traces for the AC filament
#1166 |
So red is some time not your best AC heating, blue is DC heating. 1kHz harmonics have a nice fall scale.
#1167 |
Salas. Did you try lifted AC heater.
#1168 |
Yes red is a not so good AC spectrum. If you recall I was having a bit of an issue back then with ground loops on my test bench. I know I have a clean one somewhere in my files, but that was a computer ago. The 60,120, and 180 Hz peaks were about the same magnitude however.
#1169 |
i heard reports by some local diy'ers that using a CMC on the ac filament yielded improvement, the choke is a ferite type sized to handle the current required...
http://www.elab.ph/forum/index.php?topic=32688.0 |
#1170 |
| Help me design my DAC/Line Preamp. | kuroguy | Tubes / Valves | 7 | 2nd April 2009 08:31 PM |
| preamp line ctt | richwalters | Tubes / Valves | 1 | 7th March 2008 04:34 PM |
| Preamp for Line In and Mic | blur | Instruments and Amps | 1 | 4th January 2007 04:02 PM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
| Line preamp for 2A3 amp | Petman | Tubes / Valves | 0 | 24th May 2002 03:11 PM |
