6V6 line preamp
6V6 line preamp
Old 28th October 2012, 06:03 AM   #1151
tubo is offline tubo  Philippines
Originally Posted by Tony View Post
i do not think so, look at the heater cathode voltage ratng, they should be about 300volt or so...http://tubedata.milbert.com/sheets/093/6/6AX4GTB.pdf
do not put too much faith on "rectifier tubes singing", their mission in the amp is to convert ac to dc and not have too much forward drop....
Hi tony,
Thanks for the input. Yea I got the 6ax4s for less than a dollar a pop. Actually I got them at a garage sale along with a single altec 605a for $10 bucks.
Old 28th October 2012, 11:28 AM   #1152
SGregory is offline SGregory  United States
AC voltage on the heaters for the 6v6 was inho the way to go. I tried various DC set-ups including a SSLVR and all of them sounded dead to me. So I am back to a simple tranny and a resistor to keep the voltage down to 6.1V. It is a matter of opinion though.
No Hum.
Living Life Doing the Waltz in 4/4 meter.
Old 28th October 2012, 11:47 AM   #1153
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
6V6 line preamp
same experience here...i do lift the heaters to dc though....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 28th October 2012, 11:52 AM   #1154
Yep I do as well. Lift about 20Vdc presently.
Old 28th October 2012, 11:57 AM   #1155
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Could you show a schematic. This is basically tying ground of the heater to a higher voltage tapped off mains supply? Are you using SSHV2, SGrergory?
...Shape the sound , Man!
Old 28th October 2012, 12:31 PM   #1156
Yes I use the SSHV2.
FYI, I also use a ccs as the load. I built the Bootstrap CF.
To lift the heater it is a simple, a relativly high impedance voltage divider. If you know your B+ voltage then calculate the value of the divider to get the proper voltage. You will also need to bypass the lower resistor to ground with caps. I used a 1uF poly and a 47uF electrolytic 50V I had out of my parts box. I will see if I can draw a quick schematic later and post if someone doesn't have it handy. Pretty common approach
Old 28th October 2012, 12:42 PM   #1157
buzzforb's Avatar
THanks. First time I will have done it, so just being careful.
Old 28th October 2012, 01:33 PM   #1158
Default Voltage divider for lifting heaters
Here is what I use for lifting heaters. Lots of opinion and theories as to what voltage to lift heater to. I try to keep it simple.
For me: Rule number one. Make sure that the heater to cathode voltage is within spec. Then, if feasible, select a voltage to get the heater above the operating cathode voltage slightly.
Old 28th October 2012, 02:02 PM   #1159
buzzforb's Avatar
Just to be sure. V1 is the point where your heater circuit would normally tap ground.
Old 28th October 2012, 02:11 PM   #1160
Yes. V1 is the "new ground" for the heater circuit. I just tie one leg of the heater trany out to it. In my case I rarely use the PT heater windings and opt for a seperate heater tranny. But this works in any case.
Attached photo is of complete heater supply including voltage drop resistors for 6.1V and Voltage divider for lift. You can see the caps and smaller resistors buried underneath Vdrop resistors
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
