6V6 line preamp
6V6 line preamp
Old 28th October 2012, 03:00 AM   #1131
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
Originally Posted by tubo View Post
Hi salas,
I can get one 5u4gb no problem. If I use it can I just follow your power supply scheme?
No, 5R4GB is OK too, I just asked because 5R4GY is popular, to make sure it was not a typo.
Old 28th October 2012, 03:02 AM   #1132
tubo is offline tubo  Philippines
Originally Posted by Salas View Post
Will use a regulator?
Yup! I'll be using A shunt voltage regulator kit, Which I can get from Kevin at k&k audio( saves me the trouble in sourcing parts).
Old 28th October 2012, 03:03 AM   #1133
Yes I mean 5r4gy.
Old 28th October 2012, 03:07 AM   #1134
Salas's Avatar
6V6 line preamp
Yup! I'll be using your sshv2. Which I can get from Kevin at k&k audio( saves me the trouble in sourcing parts).
I haven't authorized any Kevin at K&K audio for SSHV2. Have you got a link to it being offered?
Old 28th October 2012, 03:12 AM   #1135
I apologize for the mistake, I thought it was the same as your sshv2. It is at kankaudio.com under accessories. Again I apologize.
Old 28th October 2012, 03:29 AM   #1136
Salas's Avatar
6V6 line preamp
With Hammond 272HX and 5R4GY use that arrangement, set the reg for 300V out and use 7.5K anode load resistor. It has enough current limiting not to hammer the rectifier. If you don't have the budget for a choke use a 220R in its place. Use 5W resistors. Also a 220K 2W bleeder across C2. Avoid mercury rectifiers, they can be dangerous if they break.
Old 28th October 2012, 03:33 AM   #1137
If I do use a 5u4 do I need to change the anode load resistor?
Old 28th October 2012, 03:36 AM   #1138
SGregory is offline SGregory  United States
Is there enough heatsink for the kandkaudio regulator in this application? At 2x bias current it will be shedding quite a bit of heat for the little ones posted in the web page.
Living Life Doing the Waltz in 4/4 meter.
Old 28th October 2012, 03:42 AM   #1139
Salas's Avatar
6V6 line preamp
That would give you sufficient voltage for regulating at about 340V with 47R R1, but 5R4GY is a more open sounding tube in my opinion. But its more limpid for voltage loss. So 300V and 7.5K load does not make it worse and you can use 5R4GY.
Old 28th October 2012, 03:48 AM   #1140
Salas's Avatar
6V6 line preamp
Looks like an unauthorized variation on SSHV1 with depletion mode CCS and on board sinks not enough for 6V6 line pre. The guy maybe uses my name on the board if I can see well from some silk screen edge, beyond mentioning it and linking my thread in his text. I will email him.
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
