Old 17th October 2012, 07:36 PM   #1121
vinylkid58's Avatar
Hi Salas, I'd like to try your circuit using 6AQ5. Any thoughts?
thanks,
jeff
Old 17th October 2012, 10:10 PM   #1122
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Looks nice for load lines in triode connection, but I can't foretell, you should sort out some good bias point and try in the same general config I guess. Does not look like getting 5W as easy as the 6V6 bottle in this one, but it could be better for acoustic feedback due to smaller bottle? Maybe. Run it conservatively. Note the 250V plate limit also.
Old 17th October 2012, 10:26 PM   #1123
vinylkid58's Avatar
Ok thanks. If it doesn't sound that great, I'll go back to plan A, which was an SRPP or mu follower. I just like the simplicity of your design.
jeff
Old 17th October 2012, 10:31 PM   #1124
buzzforb's Avatar
Look at the performance of the amp. He has it listed somewhere how trioded 6v6 performs. You really should try it. Very impressive
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 17th October 2012, 10:32 PM   #1125
Salas's Avatar
6V6 was always a tone tube.
6V6GT Single Ended - 6SN7 SRPP Stereo Amplifier Trial - YouTube
Old 18th October 2012, 01:07 PM   #1126
merlin el mago's Avatar
Sounds very natural the amp using 6V6 as final stage.
Old 28th October 2012, 02:52 AM   #1127
tubo is offline tubo  Philippines
Hi all,
I've been using 6v6 linestage now for more than 2 years without any problems. I'm still in love with it and would not part with it. Thank you very much salas!
My friend heard the preamp in his system and would like me to build him one, so we got the power transformer and choke for the project. Trouble is I do not know how to use psud to get the optimum performance from the power supply. ( (I really do not know how to use the psud)
I need help on designing a proper power supply, Please help!
Hammond 272hx power transformer
Hammond 193j
5r4gb rectifier, type 83 mercury rectifier,
4.7 if oil cap
470uf caps
Any input is greatly appreciated. Thank you
Ivar
Old 28th October 2012, 02:55 AM   #1128
Salas's Avatar
5U4GB maybe?
Old 28th October 2012, 02:58 AM   #1129
Hi salas,
I can get one 5u4gb no problem. If I use it can I just follow your power supply scheme?
Old 28th October 2012, 02:59 AM   #1130
Salas's Avatar
Will use a regulator?
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
Copyright ©1999-2013 diyAudio
