6V6 line preamp
6V6 line preamp
Old 11th September 2012, 06:49 PM   #1101
yagoolar is offline yagoolar  Poland
yagoolar's Avatar
Send a message via ICQ to yagoolar 6V6 line preamp
Less than 4EUR/pcs so really no big deal. The big deal is inspiration from you, Salas.
Old 11th September 2012, 11:43 PM   #1102
6L6 is offline 6L6  United States
6L6's Avatar
6V6 line preamp
Measured the heater current, both 6V6 together pull 1.9A AC from the heater winding.
Voltage doubler is pair of 1n4002 and pair 2200uf caps, feeding lm317 in regulator configuration that's right off the data sheet.
Old 11th September 2012, 11:57 PM   #1103
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
Has to draw more current from the source to double the volts, doesn't it?
Old 12th September 2012, 12:22 AM   #1104
6L6's Avatar
6V6 line preamp
Yes, of course.
The info that I had was that it would draw quite a bit more than that...
I will probably make an individual reg for each tube, as previously discussed.
Old 12th September 2012, 12:48 AM   #1105
Salas's Avatar
6V6 line preamp
It draw ~(0.45+0.45)=0.9A from the reg and it would be 1.8A from the source if the power efficiency was 100% and the tubes draw spot on spec. So 1.9A from source looks quite fine.
Old 12th September 2012, 01:00 AM   #1106
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
One reg with a LM338T, up to 5 amps draw.
jeff
Old 12th September 2012, 01:21 AM   #1107
Salas's Avatar
6V6 line preamp
To use the most waste heat efficient approach is the priority I think. That would be a low drop out voltage regulator with mains worse case drop kept in mind and a sink that will keep it long term reliable. Each time we halve the temp we quadruple life expectancy in electronics.
Old 12th September 2012, 02:27 AM   #1108
6L6's Avatar
6V6 line preamp
A bigger heatsink I have.
Is there a better regulator (lower dropout) for this application?
Old 12th September 2012, 02:40 AM   #1109
Salas's Avatar
6V6 line preamp
LT1085 is a known one, there are many.
Old 12th September 2012, 03:50 AM   #1110
harlee is offline harlee  Singapore
This is a wonderful line amp, have been listening to it for the past week.
But it seems to have a bit too low a gain, I crank it all the way up and it's still bearable. Was the gain at 15? Must have lost it some where?
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
