#1091 |
#1092 |
diyAudio Chief Moderator
Based on your schematic and data I constructed a sim. Things of notice are:
1. Substantial voltage has to be be dropped across some series ballast to protect the tube cascoded chip for max current. As you did with your RC cells. 2. Ripple eating is so so but it works. Fed 2Vpp 100Hz dc source ripple and 10mApp 1kHz load play in the sim. 140-180mVpp on output. 12.5 times rejection on average (22dB). 3. The output capacitor looks better placed across the high value resistor and trimmer leg for filtering the TL431 ref node. Its a noisy enough chip by itself and that resistor combo is big for Johnson noise. Don't know about stability in that case, it takes much more elaborate modeling and feedback nodes breakage of some full TL431 sub circuit. A practical test would tell much faster. Zo goes higher the opposite way for cap full output shunt or resistor leg shunt, has to do with its bootstrapping the ref or not also. Thus it eats 100Hz ripple stronger due to AC feedback (pic3). |
#1093 | |
Yes, the heaters are only .45A, but the voltage doubler is a current thief, according to Broskie, you only get a bit more than 25% of the winding's AC current rating. (AC current/3.8 = DC current) |
#1094 |
True you win some you lose some when transforming tension and current abilities, still 1.5A would cater if you had to.
#1095 |
Hi Salas,
Thanks for the update, as it is, didn't hear any instability. Have been using for a week now, seems ok, did change the 10uF across to the resistor and TL431 ref point this morning though, still run as good. Thanks again. Keep it coming if there is any more recommendations. |
#1096 |
Was talking about the change mainly, so it proved stable too. Did it make any subjective change?
#1097 |
Didn't notice any changes.
I am now looking at the Tungsol cryo, what is the difference in soundwise? |
#1098 |
Don't know, I only have the regular set. Not so expensive though. I hope they do not compromise them mechanically during the freeze and thaw cycle at least.
#1099 |
#1100 |
They are melodic tubes, I have them. A couple went noisy in a batch of ten but they were cheap back then, so no big deal.
| Help me design my DAC/Line Preamp. | kuroguy | Tubes / Valves | 7 | 2nd April 2009 08:31 PM |
| preamp line ctt | richwalters | Tubes / Valves | 1 | 7th March 2008 04:34 PM |
| Preamp for Line In and Mic | blur | Instruments and Amps | 1 | 4th January 2007 04:02 PM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
| Line preamp for 2A3 amp | Petman | Tubes / Valves | 0 | 24th May 2002 03:11 PM |
| Page generated in 0.20470 seconds (100.00% PHP - 0% MySQL) with 10 queries |
