Old 7th September 2012, 07:50 AM   #1061
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by harlee View Post
Hi, I have completed the 6V6 line amp built, indeed the sound is big!
I have used Salas' standard line circuit with a 6L6GC shunt regulator. Using the parts that I have, B+ is 292V, 18mA through the circuit.
Thanks Salas!
Hi, I would recommend you use a higher load value in these conditions. Try adding 2.7K 3W-5W resistor in series to the 5K anode load one and tell us if it got better or not. Pictures would be nice too.
Old 7th September 2012, 10:31 AM   #1062
Still listening to mine every day. I've since
changed the B+ regulator to a 6V6 shunt
regulator with DC heaters dialed in at 340V with a larger
transformer. My amplifier can reach full
volume without Salas' pre but it sounds
lifeless. Thanks again for this beautiful
design Salas
Old 7th September 2012, 10:54 AM   #1063
Salas's Avatar
Nice when something still delivers to taste, standing the test of time. You are welcome, regards.
Old 7th September 2012, 01:19 PM   #1064
disco is offline disco  Netherlands
disco's Avatar
Originally Posted by 6L6 View Post
I have been messing with the circuit today and have learned a few things -
I have got some hummm, but I think it's a wiring problem. It goes away when the pot is turned all the way up or down, and worst at the mid-position.
I think I also have some filament hum, as they are AC for now. I will put together a quick and dirty regulator for them tomorrow.
My 6V6 pre works fine AC heated, perhaps you should have a look at the routing of your wiring?
Here's a pic I made for someone else, suffering from grounding issues. Maybe it's to your service.
jaap
Old 7th September 2012, 01:38 PM   #1065
6L6 is offline 6L6  United States
6L6's Avatar
Yes, I'm quite sure it's a wiring problem!
It's all a bird's nest of wire, strung all over my workbench. However, there is some insight in your diagram, and I will make a few changes. Thanks!!
llustrated Build Guides - Pass Pearl 1 - Pass B1 - - Pass F5 - Pearl 2 - -O2 HPA - -
Pass F4
Old 7th September 2012, 07:49 PM   #1066
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Do I see a GND Loop there ?
RC
Old 7th September 2012, 08:12 PM   #1067
tinitus is online now tinitus  Europe
signal RCA plugs should be isolated from chassis/case
dont know about grounding the att
Old 7th September 2012, 09:10 PM   #1068
disco's Avatar
Tinitus: The RCAs must be isolated from a conductive chassis indeed.
Would you break up the signal ground and take it to the star directly?
Roberto: In reality the lines you made red are one and the same. Starground(s) and chassis connection is made to the capacitor that has the lowest ripple current to keep large loading currents from the ground. Star topology is used to prohibit larger currents to interfere with smaller currents. Exhaustive runs of grounding cables seem to work contra productive, possibly because of the extra inductance.
New scheme:
jaap
Old 7th September 2012, 09:43 PM   #1069
I suppose thats the point of having a starr ground, if there is one
though I prefer to look at it like multiple starr gounds, along the same string
often you see tube amp builders have one(and only one) solid core wire going through the whole amp, for all ground connections
and you often see the signal ground isolated from chassis/earth by a small resistor, or maybe a thermistor(look at NelsonPass DIY)
Old 8th September 2012, 07:25 AM   #1070
harlee is offline harlee  Singapore
You're Great Salas!
I found 2.2K/3W somewhere and put it in series with the anode resister of 4700K, and it brought the sound back down, it sound more alive. It was a bit floating especially the high.
Just wondering how it sound with 330V B+?
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
Copyright ©1999-2013 diyAudio
