Old 6th September 2012, 01:52 AM   #1051
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by 6L6 View Post
The (basic) schematic of the regulator.
Salas, yes, I will play around with the tone of the bypass cap. At the minimum I plan to have a film bypass of some sort.
It does not look like a full reg, more like a current boosted voltage reference. Q1 in series should be strong enough for 40mA total bias 2 channels. What Mosfet type is it? What are the values of R2,C2? If you will have no cap across Rk you are introducing full band cathode degeneration, i.e. local feedback. With a small film you introduce it just in low freq. So normalize the SPL on pink noise with a slowly integrating meter like the Radioshack one if you are to compare with an electrolytic there, without is gonna be less gain and different THD. Nice turret board btw. This config you got is flexible enough to decide how you like it or not.
Old 6th September 2012, 02:15 AM   #1052
Salas's Avatar
P.S. See what happens to freq. resp. and phase for 0uF 1uF 10uF 47uF 100uF 220uF 330uF 470uF 1000uF Ck values. 1000uF is light blue to graph's left and the rest are as we go down lower the values list moving to graph's right. 10dB bottom blue line is no Ck.
Old 6th September 2012, 02:32 AM   #1053
6L6 is offline 6L6  United States
6L6's Avatar
It's in my workroom which is accessed through my (sleeping) toddler's bedroom. I will report back tomorrow.
Also, that's not the exact schematic, but close. It's an older version of the same idea. I'm not dropping too many volts so dissipation should be fine, it's a big transistor. I have bigger heatsink if necessary.
If I can find the exact schematic will post it.
It's worth mentioning that one can replace the first R with a choke, I am going to try that tomorrow. The reg circuit would have even less ripple to control with a choke instead of a resistor, yes?
So do you mean that a small film in parallel with the 1000uf is bad or does something different? I didn't mean to say that I was only going to use the small cap with no electrolytic.
Ok, you lost me.
Yes, it's very nice. They are available from Antique Electronic Supply, and (unfortunately) are quite expensive these days. There are many configurations.
llustrated Build Guides - Pass Pearl 1 - Pass B1 - - Pass F5 - Pearl 2 - -O2 HPA - -
Pass F4
Old 6th September 2012, 02:40 AM   #1054
6L6's Avatar
Ok, I understand what the different values do now in this circuit. It also looks that 470uf will be 'close enough' to the 1000uf that it will get me going without it being too different. Yes?
Pass F4
Old 6th September 2012, 03:02 AM   #1055
Salas's Avatar
-I don't mean its not gonna have good enough voltage, it will not dynamically maintain it is the difference to a real reg, but don't bother its just a remark on the schematic's taxonomy. if its recommended to exchange a specific R with an L by Welborne then try it and compare, why not.
-Clarifying it was about simply bypass, ignore the very small values graph lines then, still see the value progression phase lines, how it turns down low. That is nice to keep in mind when auditioning this or that brand cap when the values are adequate but not the same.
-If gain is different between any circuits or there is bass region energy extension difference we should normalize the SPL with care to they surely sound exactly as loud for proper AB comparisons is what I was talking about.
-Maybe any less expensive alike turret boards on ePay? Its worth looking around for such stuff when building with da tubez.
Old 6th September 2012, 03:04 AM   #1056
Salas's Avatar
Correct.
Old 6th September 2012, 03:30 AM   #1057
6L6's Avatar
Yes, it is not a real regulator, more of a capacitance multiplier and voltage reference. Sorta. Anyway, it should help make the PSU quiet, if all works properly... I mainly want to use it, just to use it! It's been sitting in a box for about a decade.
After looking at the (current version) schematic on the Welborne website it actually isn't substituting a choke for one of the resistors... It's showing a CL before the regulator. Which is quite easy to implement, so it will be tried.
And that is a very good point that might be missed by some people.
Ah, yes, I understand. I thought you were talking about something electrical in the bias circuit, not the overall gain due to the bypass.
Yes, it's certainly worth looking. But I have this one already.
Pass F4
Old 6th September 2012, 06:20 AM   #1058
triode_al's Avatar
  • B+ 13v off, a paltry few percent, I'm sure it will be fine for the time being.
  • the screen resistor, the closest thing in my was 150ohm, is that going to be a problem?
  • the cathode bypass cap, I've nothing close to 1000uf. I can parallel a few to get 440uf, or go much bigger, 2200uf.
  • A slight deviation off an abstracted and averaged anode voltage is OK, every tube might be different anyway; don't worry and as you test it it will test good
  • The screen resistor acts as a damper and 150 ohm damps OK
  • On my R120 project I have used 68 uF (solid tantal, mil grade, good on HF) on my cathodes and it works well, with a -3dB of about 4-5 Hz. Good enough.
DAC TDA1541 S1; MC30-Super --> two stage RIAA; SP-6 clone ; 300B PP: 6N7/ECC82, Metalimphy output.
Old 7th September 2012, 01:17 AM   #1059
harlee is offline harlee  Singapore
Hi, I have completed the 6V6 line amp built, indeed the sound is big!
I have used Salas' standard line circuit with a 6L6GC shunt regulator. Using the parts that I have, B+ is 292V, 18mA through the circuit.
Thanks Salas!
Old 7th September 2012, 04:29 AM   #1060
6L6's Avatar
I have been messing with the circuit today and have learned a few things -
I have got some hummm, but I think it's a wiring problem. It goes away when the pot is turned all the way up or down, and worst at the mid-position.
I think I also have some filament hum, as they are AC for now. I will put together a quick and dirty regulator for them tomorrow.
I didn't write down any notes (which is stupid) but from memory the B+ is 310v under load, the anode has 200v, and the cathode 13v
The regulator schematic, for those who are interested -
The zener stack controls the output voltage, so I can increase the regulated output by changing the zener string and tweaking the 8.2K resistor.
The power transformer I'm using is a bit too low voltage to get the full 320v. I will change it for another, that should make a difference.
I also want to experiment with an unregulated supply, CLCLC, I have a pair of 15H chokes.
Pass F4
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
Copyright ©1999-2013 diyAudio
