| diyAudio Sponsor | ||
Would anybody know if there is a substitute for the 6gw8 ?
I was given a Heathkit Stereo aa-32 amplifier which uses the 6gw8 in a push pull output. I find some threads that say that the 6bm8 can be used if the socket is rewired, which I am capable of doing. Would appreciate any help possible. thank you oldheathkitphil
oldheathkitphil |
#2 |
At $9.00 new / 4.50 used, I'd just buy a few... try findatube.com
Or add a 6V transformer in series with the heaters and get some 14GW8s... They really should be matched though, especially if this amp uses one common cathode resistor like many lower-end amps... |
#3 |
The 6GW8 is the same as the European ECL86 and is quite readily available. Cost is very variable depending on who made them.
www.kta-hifi.net |
#4 |
Worth chasing up old stock tubes. The 6GW8 is a seriously lovely sounding tube. It is the best of all of those triode/pentode combinations, a lot better than 6BM8 in my opinion. Now - if only we can convince someone to start making them again.
I've put 12 off them into my stock to make sure my 6GW8 amps outlast me. Cheers, Ian |
| 6GW8 substitute tube 6BM8? | rajuncajun | Tubes / Valves | 0 | 1st December 2008 05:13 AM |
| 6gw8 /ECL86 El Cheapo modifications | bbuz | Tubes / Valves | 13 | 24th June 2008 01:16 AM |
| Quick Ecl86/6gw8 Amp | cammy666 | Tubes / Valves | 2 | 12th July 2007 02:48 AM |
| 6L6 for a beginner, plus ECL86/6GW8 | jsp | Tubes / Valves | 22 | 8th April 2007 10:09 PM |
| Help with 6GW8/ECL86 tubes?? | fluckscapacitor | Tubes / Valves | 5 | 11th October 2005 02:46 AM |
| Page generated in 0.07993 seconds (70.91% PHP - 29.09% MySQL) with 10 queries |
