Getting rid of oscillations in the preamp
Old 22nd May 2007, 02:04 PM   #1
engels is offline engels  Israel
engels's Avatar
Default Getting rid of oscillations in the preamp
I've made a bass preamp with two 5670's. It has two channels with #1 being the "simple" one - only a volume control - and #2 being the "complicated" one with the fender twin style TMB tone stack. Here's the schem:
Voltages measured:
B+ = 286V
anodes: 112V to 122V
cathodes: 3.3V to 3.58V
when channels run in parallel everything's very good and you can only wonder how much gain TMB runis - channel one is at least twice louder.
with channels in series (channel 1 out into channel 2 in) oscillations start when there's too much volume on either channel. Like, with c.2 volume on maximum everything sounds good untill volume on channel 1 is under 3 (about 450K on the 500K pot). When you pass 3 and the vol. pot resistance is around 400K a nice squeal starts and if you go further you get a nasty oscillator scream. If you max the channel one and lower the second channel's volume there's about the same thing, only you get more distortion before the squeal starts and it also happens when the volume (tihs time on ch.2) is less than 400K.
Bass preamp should be more in a hi-fi preamp field (it's NOT a guitar pre), I don't need any distortion at all. I was thinking about some solutions but cannot deside which one is the best.
My primitive ideas include: puting a series 220K resistor on channel 1 output; lowering the ground reference resistors on both channels outputs to, say, 100K.
Or maybe everything is wrong and the tubes should be biased differently to get rid of the oscillations?
by the way, I like the sound of the preamp, although there's something wrong when the channels are in series close to the oscillation point - some additional harmonics appear when a strong signal is on the input. What's that?
Old 22nd May 2007, 02:20 PM   #2
engels's Avatar
Default additions
Sorry, forgot:
5670 datasheet
5670 DuncanAmps' info page
pictures:
Old 22nd May 2007, 02:45 PM   #3
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
Nice job!
With more than 2 cascaded stages, decoupling is a must. Feed the B+ to each stage with a 10K resistor and 22 uF or larger bypass - this will keep anything above 5 Hz from sneaking from stage to stage through the power supply. But 4 stages is just TOO much gain - you have a potential gain of 30*30*30*30, with input and output 1/4" apart on that switch! Removing cathode bypass caps might be a start...
Old 22nd May 2007, 07:46 PM   #4
kstagger is offline kstagger  United States
kstagger's Avatar
if you haven't already - I would add a carbon comp grid stopper after the volume control/close to the grid.
Old 23rd May 2007, 03:54 AM   #5
kevinkr's Avatar
Feedback through the power supply, at the least shunt that last electrolytic with a good film cap to lower its impedance at high frequencies, better still split off one stage before and power each gain block from its own decoupled supply. Keep voltages about the same.
Add grid stopper on second stage 5670 right at the socket.
Unbypassed cathode resistors will add some noise particularly at high gains. I would instead add an output attenuator for use when you loop things in series - this would ideally be in the first stage output and the attenuated output would be used to drive the second stage with the tone stack. I don't think you really want all of that gain anway..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 23rd May 2007, 07:29 PM   #6
engels's Avatar
Default options
I think I simply need to get rid of too much gain. The oscillations start after a pretty heavy distortion which I don't need. I'm not sure where they bleed from but I'm afraid anything I will do will not help because it's just too much gain.
I would not add more grid stoppers after volumes just because it works good in parallel and any additional stuff in the signal chain might make it muddy.
An output attenuator at the end of the 1st stage seems to me to be the best option, it may be even good for the parallel since the first stage is much louder than the 2nd.
But what sort of attenuator? Voltage divider? Series resistor? low ground reference?
Old 23rd May 2007, 08:24 PM   #7
kevinkr's Avatar
Stick the attenuation in series with the volume pot or because of the pots high value connect it across the lower resistor in the attenuator pair. You could also change to a lower value pot. My concern is high frequency performance could be degraded by the shunt capacitance across the pot. Tweak values so that levels match fairly well or do what you need.
The cross talk is in the supply, and I am doubtful that the electroytics you have chosen have particularly good performance above a couple of kHz. I'd still shunt the last one in the filter with a good film cap of a couple of uF.
The grid stoppers will not affect tone or frequency response, particularly in comparison to the source impedance that pot represents around mid point. I would recommend something on the order of 1K for much better resistance to rf pick up.
Kevin
Old 24th May 2007, 03:30 PM   #8
richwalters is offline richwalters
richwalters's Avatar
You don't mention the chassis material....doesn't look metal .....Is this a workers plastic lunchbox ? If so things will run wild.
A simple screening can on each tube may solve oscillations but ruin looks.
Often, I have to do this treatment with ECC88's.
richj
Old 24th May 2007, 04:51 PM   #9
kevinkr's Avatar
Looks a lot like the stamped metal lunch box I had as a kid.
Old 24th May 2007, 08:08 PM   #10
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Looks like a steel security box to me, with a lock to stop people fiddling with the innards - should be robust. Nice colour.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Getting rid of oscillations in the preampHide this!Advertise here!
Chip Amp Oscillations!!! john65b Chip Amps 10 30th December 2007 03:31 PM
oscillations IN OPAMP help ???? prorms Solid State 3 30th September 2007 12:17 PM
Oscillations in P3A ?? Stormo Solid State 3 20th January 2003 09:34 PM
amplifier oscillations lowfi Pass Labs 33 29th May 2002 07:32 PM
Aleph 3 oscillations Koy Pass Labs 4 22nd April 2002 04:56 PM
