diyAudio Sponsor
Old 22nd May 2007, 11:44 AM   #1
exurbia is offline exurbia  Australia
exurbia's Avatar
Default has anyone used the 4-125A in SE amp ?
I have a collection of these valves, whilst i have an application for a push/pull amp i don't want to build it.
I would like to know if the valve is suited to single ended applications.
Old 22nd May 2007, 01:00 PM   #2
rcavictim's Avatar
Best way to find out may be to try it. The high plate voltage (3000+) and low (400 IIRC) G2 voltage will be a problem in that you will need a separate G2 supply. I think I`d be tempted to tie both grids together and use as driving grid making a seldom employed triode connection. Gain will be low so large driver swing will be required if you go this route. The 4-125A looks very impressive all lit with plate glowing a dull orange at rated dissipation.
I.Q.Test. Have you ever purchased a recreational snowmobile?
Page generated in 0.05403 seconds (68.68% PHP - 31.32% MySQL) with 9 queries
