Old 23rd May 2007, 02:12 AM   #11
ashok's Avatar
Yes, that did occur to me and I refered to that in my post . However the V2 grid is at ground potential and so there is no way that the cathode could also be at zero volts . So it still looks like it ( - V ) wasn't required ...........isn't it ?
The direct coupled stage is simpler and does the job very well. Is there any sonic improvement in the scheme that is shown with 3 supplies ?
AM
Old 23rd May 2007, 12:05 PM   #12
ilimzn is offline ilimzn  Croatia
Originally posted by EC8010
A 6SN7 cathode follower could operate from the +250V rail (losing the +125V rail). The more significant problem (which others have highlighted) is that the first stage has too much gain; 12B4A (mu = 6) would make more sense.
Note that there is local feedback in the first tsage lowering it's gain.
Frank's 6SN7 line stage / preamp with GlassWare PS-1? Evenharmonics Tubes / Valves 2 24th July 2011 03:20 PM
12AU7 Preamp build mattthegamer463 Tubes / Valves 72 4th June 2009 02:51 AM
Look for 12AU7 Preamp Circuit . RCA245 Tubes / Valves 2 2nd June 2006 02:02 PM
Search for a pre (RIAA+LINE+TUNER)with 12au7-12ax7. bronto64 Tubes / Valves 0 19th April 2004 08:50 PM
5814/12AU7 Preamp? JojoD818 Tubes / Valves 15 13th April 2004 04:04 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
