| diyAudio Sponsor | ||
Can anyone help me with a cascode DN2540 50mA plate load design? I've seen some of Gary P's designs, but his site is no longer available and what is available is sparse in practical information. Thanks!!!
They seek him here, they seek him there... |
#2 |
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#3 |
Jack, here is what I've been using. For the grid-stoppers, the value will depend on your layout and the particular resistors, but 1k should be safe. I used 300R. The lower bias resistor will set the current- for the batch of DN2540 I have, 120R gave me 20mA, 300R gave me 10mA.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#4 |
Hi Jack,
Check out the articles at http://www.raleighaudio.com/MI%20articles.htm Also take a look at the line stage at http://www.raleighaudio.com/active_schematic.htm The resistors around the MOSFETs are 2.4K and, the diodes are 18V Zener. The resistor in the source sets the current. The value of this resistor must be found empirically because the characteristics of the MOSFETs vary from lot to lot. Dave |
#5 |
Ooops, Jack points out that the symbols in my drawing were wrong- they should be N, not P. Otherwise, the drawing is correct.
| diodes before plate load | alexg | Tubes / Valves | 2 | 3rd March 2008 01:26 PM |
| Plate load resistor question | Carlp | Tubes / Valves | 14 | 21st January 2008 01:41 PM |
| Pentode Plate Load | dsavitsk | Tubes / Valves | 14 | 4th July 2007 07:47 PM |
| bypassing the plate-load | memphissound | Tubes / Valves | 3 | 12th December 2006 12:46 PM |
| Aleph-type CCS as plate load? | Fuling | Tubes / Valves | 18 | 22nd October 2004 02:46 AM |
| Page generated in 0.07647 seconds (74.83% PHP - 25.17% MySQL) with 11 queries |
