| diyAudio Sponsor | ||
Any idea were i can get some "point to point" board from?
I dont know what the proper name is! Im in the UK and carnt find it anywhere. Cheers Damon McCartney |
#2 |
Perhaps you mean turret terminal board? Try googling on that, I think you'll find several suppliers. Be prepared though, it's quite expensive.
www.kta-hifi.net |
#3 |
Lots of smaller companies in the USA willing to send that stuff to the UK.
Try http://www.turretboards.com/ He has boards, turrets and tools as well as other supplies at a reasonable price. Or if your just looking for parts, Keystone Turrets are pretty much a standard. A Good board material is .125 thick GP03 In the USA I buy board material from McMasters http://www.mcmaster.com/ In their seach box use This number 8549K74 Keystone makes good turrets. I buy Them from Mouser. http://www.mouser.com/search/Product...x?R=534-1509-4 Mouser Part #: 534-1509-4 Manufacturer Part #: 1509-4 http://www.mouser.com/catalog/630/1541.pdf You should be able to track down those items in the UK also. Trout |
#4 |
There have been a number of threads concerning this subject. Use the search feature, and look for "turret" or "terminal".
One good discussion was: Hoffman Amps Turret Lugs? |
#5 |
I sell turret and tag boards as well. Anything specific you need? Cheers! |
#6 |
You can always use double side copper boards and solder some tag boards for easy p-p assembly and ground schem. Have a look at my recent project.
Regards, George |
#7 |
Also....
#8 |
Hi Guys cheers for all the responses!
I did search for similar posts but i really didnt know what the name of it was so was unsure what to search for. Ill have a look at your recomendations and let you know how i get on! Again cheers all, Damon |
#9 |
Search for the words "turret" or "terminal" under the "Tubes" forum.
| Wire Wrap connections for point to point | mashaffer | Tubes / Valves | 10 | 7th July 2007 01:11 PM |
| Benifits of point to point wiring for digital circuit? | MGH | Digital Source | 15 | 14th September 2006 10:17 PM |
| aleph - any point-to-point builders? | HeadSh0T | Pass Labs | 15 | 8th November 2004 09:35 AM |
| Anyone use magnet wire for point to point wiring projects? | Hybrid fourdoor | Parts | 10 | 2nd February 2004 08:11 AM |
| Audio Note's Kit One done in point-to-point wiring | Wram | Tubes / Valves | 18 | 29th April 2003 10:59 PM |
| Page generated in 0.09068 seconds (77.06% PHP - 22.94% MySQL) with 11 queries |
