diyAudio Sponsor
Old 20th May 2007, 06:02 PM   #1
arvin is offline arvin  United Kingdom
Default SE bass
I have 2 music angel amps.
one is a 65 watt push pull EL34
the other is a Single Ended 845 20 watt amp.
The se45 20 watt sounds much better than the el34, but despite its lower output has much more bass.
Why?
Old 20th May 2007, 06:09 PM   #2
SY's Avatar
Low damping factor.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 20th May 2007, 06:23 PM   #3
xaviery is offline xaviery  France
Another reason may be: the output transformer of SE amp is better than that of push-pull amp
Old 20th May 2007, 06:36 PM   #4
SY's Avatar
Or worse. A big whack of second harmonic will subjectively fatten up the bass.
Old 20th May 2007, 08:32 PM   #5
jlsem is offline jlsem  United States
jlsem's Avatar
So how does a second harmonic at, say, 30dB below the fundamental cause louder sounding bass of, say, a noticeable 3dB? I would put the blame on a saturated OPT.
John
Old 20th May 2007, 09:06 PM   #6
SY's Avatar
I'd agree with that.
Old 20th May 2007, 09:50 PM   #7
so all else being equal a s/e shouldn't sound bassier than a push-pull design?
Having said that, I do like the sound of the 845 tube, they are monster tubes and the midrange projection is awesome.
Old 20th May 2007, 10:21 PM   #8
spa317 is offline spa317  Australia
Default Music Angel 845
I have a Music Angel 845 also, and find the bass and performance to be great! If you havent already, try some better input/driver tubes, some NOS Philips/Sylvanias worked wonders for me.
My next step is to try some better quality 845 tubes, from SuperTNT (metal plate).
Enjoy your amp!
Mark
Old 20th May 2007, 10:32 PM   #9
Thanks for the advice Sir, I will just do that.I do like music angel amps, they are very heavy though.
Old 21st May 2007, 12:06 AM   #10
Milen is offline Milen  Bulgaria
Send a message via ICQ to Milen Send a message via Skype™ to Milen
For better bass can help the deeper negative feedback. Mostly PP amps doesn't have feedback...
Dipole bass or Ripole Bass? MJL21193 Subwoofers 13 15th September 2008 07:42 AM
any electric bass players? im building a bass guitar cab KOA Instruments and Amps 27 30th April 2007 03:49 PM
DBA (dual bass arrays) and active bass traps capslock Subwoofers 3 20th August 2006 12:52 PM
32 ohm bass amp. Tweeker Tubes / Valves 5 9th March 2006 12:43 AM
For all Bass Junkies out there (Behringer Bass processor usage report) VEC7OR Digital Line Level 5 27th October 2003 09:18 AM
Page generated in 0.15005 seconds (51.51% PHP - 48.49% MySQL) with 11 queries
