| diyAudio Sponsor | ||
Does anyone know what the 580 is in the B1 equation?
*Vacuum Tube Triode (Audio freq.) pkg:VT-9 (A:1,2,3)(B:6,7,8) .SUBCKT X12AX7 1 3 4 B1 2 4 I=((URAMP((V(2,4)/85)+V(3,4)))^1.5)/580 C1 3 4 1.6E-12 C2 3 1 1.7E-12 C3 1 4 0.46E-12 R1 3 5 50E+3 D1 1 2 DX D2 4 2 DX2 D3 5 4 DX .MODEL DX D(IS=1.0E-12 RS=1.0) .MODEL DX2 D(IS=1.0E-9 RS=1.0) .ENDS X12AX7 |
#2 |
Looks like the 3/2 power law for a triode with some other constants thrown in:
Ip = G (Vp/Mu +Vg)^1.5 URAMP must be defined somewhere earlier as a constant or else is some predefined function routine of (.....)
Ohms Law V = I R |
#3 |
The number changes with the type of tube. It doesn't seem to match any of the tube parameters though.
#4 |
The inverse of Gm I think. Gm of a 12AX7 is ruffly 1.8mA/V and 1/0.0018 = 556
#5 |
I first thought that too till I tried the theory on the other models
*Vacuum Tube Triode (Audio freq.) .SUBCKT X6SN7 1 3 4 B1 2 4 I=((URAMP((V(2,4)/20)+V(3,4)))^1.5)/1086 C1 3 4 2.6E-12 C2 3 1 4.0E-12 C3 1 4 0.7E-12 R1 3 5 10E+3 D1 1 2 DX D2 4 2 DX2 D3 5 4 DX .MODEL DX D(IS=1.0E-12 RS=1.0) .MODEL DX2 D(IS=1.0E-9 RS=1.0) .ENDS X6SN7 *Vacuum Tube Triode (Audio freq.) pkg:VT-9 (A:1,2,3)(B:6,7,8) .SUBCKT X12AU7 1 3 4 B1 2 4 I=((URAMP((V(2,4)/18)+V(3,4)))^1.5)/1151 C1 3 4 1.6E-12 C2 3 1 1.5E-12 C3 1 4 0.5E-12 R1 3 5 10E+3 D1 1 2 DX D2 4 2 DX2 D3 5 4 DX .MODEL DX D(IS=1.0E-12 RS=1.0) .MODEL DX2 D(IS=1.0E-9 RS=1.0) .ENDS X12AU7 |
#6 |
Triode: Ip = G (Vp/Mu +Vg)^1.5
Gm = (del Ip)/(del Vg) = (1.5)G(Vp/Mu + Vg)^.5 = (1.5) (G^.6666) (Ip^.3333) You need to know what URAMP(...) is doing.
Ohms Law V = I R |
#7 |
Banned
From the SPICE docs:
uramp(x) = x if x > 0, else uramp(x) = 0 ("Unit ramp function") |
#8 |
"From the SPICE docs:
uramp(x) = x if x > 0, else uramp(x) = 0 " Ah!, Thanks Andy. So they don't want any positronic tubes I guess. No negative plate current allowed. So the mystery number is left to be 1/G G = Ip/( (Vp/Mu + Vg)^1.5 ) = ( .6666 gm/ (Ip^.3333) )^1.5 Just plug in some tube data numbers into the G formula and you have it. Don
Ohms Law V = I R |
#9 |
I've been hacking these models for a while. Here's one with comments:
*Vacuum Tube Tetrode (Audio freq.) .SUBCKT X38HK7P A S G K * * Calculate contribution to cathode current * *the number at the right end determines sharpness of knee Bat at 0 V=0.636*ATAN(V(A,K)/12) *the URAMP(V(S,K)/# mostly determines peak plate current, grid line spacing nearly constant *the number at the right end determines slope of grid lines (plate resistance) Bgs gs 0 V=URAMP(V(S,K)/3.27+V(G,K)+V(A,K)/90) *the exponent sets the linearity of grid line spacing, and big impact on peak plate currrent Bgs2 gs2 0 V=V(gs)^1.58 Bcath cc 0 V=V(gs2)*V(at) * * Calculate anode current, grid line spacing adjust and peak plate current * Ba A K I=2.65E-3*V(cc) * * Calculate screen current * Bscrn sc 0 V=V(gs2)*(1.1-V(at)) Bs S K I=0.9E-3*V(sc) * * Grid current (approximation - does not model low va/vs) * Bg G K I=(URAMP(V(G,K)+1)^1.5)*50E-6 * * Capacitances * Cg1 G K 17p Cak A K 6.5p Cg1a G A 0.6p .ENDS X38HK7P But your code looks a bit different. But I think it might be plate resistance. Set up a test circuit that creates curves in Circuitmaker, and vary one variable at a time, and see what it does. Below is "pentodecurv.ckt" "URAMP" looks to be something that stops at zero. So you never get current going from cathodes to plates (aka electrons going from plates to cathodes). CircuitMaker Text 5.6 Probes: 5 v1#branch AC Analysis 0 130 22 65280 v1#branch Operating Point 0 130 22 65280 v1#branch Transient Analysis 0 130 22 65280 v1#branch Fourier Analysis 0 130 22 65280 v1#branch DC Sweep 0 132 24 65280 41 35 62 4 97 108 86 46 82 16 73 113 113 59 105 107 0 5 0 1e+09 0.001 2 33 13 10 13 12 18 10 20 20 12 20 10 13 13 10 20 13 46 20 14 20 18 17 14 16 20 20 20 20 10 13 20 18 11 0 0 30 100 10 176 75 1020 719 7 5.000 V 7 5.000 V 3 GND 0 0 24 100 0 1 0 20 Package,Description, 30 C:\PROGRAM FILES\CM60S\BOM.DAT 0 7 2 4 0.500000 0.500000 344 171 1188 493 144179218 0 0 0 0 0 0 0 18 2 +V 167 715 42 0 1 3 0 3 0 0 0 53744 0 4 200V -14 -23 14 -15 3 V10 12 -12 33 -4 0 0 13 %D %1 0 DC %V 0 0 0 3 0 1 1 0 86 0 0 0 1 0 0 0 1 V 5130 0 0 2 5.89301e-315 0 0 7 Ground~ 168 540 162 0 1 3 0 2 0 0 0 53360 0 0 4 GND4 -14 -26 14 -18 0 4 GND; 0 0 0 0 3 0 1 1 0 0 0 0 0 1 0 0 0 3 GND 391 0 0 2 5.89301e-315 0 0 9 V Source~ 197 661 71 0 2 5 0 3 5 0 0 0 16752 0 2 0V 15 -2 29 6 2 V9 15 -12 29 -4 0 0 11 %D %1 %2 %V 0 0 0 5 0 1 2 1 2 0 86 0 0 0 1 0 0 0 2 Vs 3124 0 0 2 5.89301e-315 0 0 9 V Source~ 197 550 51 0 2 5 0 7 6 0 0 0 16752 0 2 0V 15 -2 29 6 2 V8 15 -12 29 -4 0 0 11 %D %1 %2 %V 0 0 0 5 0 1 2 1 2 0 86 0 0 0 1 0 0 0 2 Vs 3421 0 0 2 5.89301e-315 0 0 8 Tetrode~ 219 551 117 0 4 9 0 6 5 4 2 0 0 0 336 0 4 7695 26 -30 54 -22 2 V7 47 -26 61 -18 0 0 17 %D %1 %2 %3 %4 %S 0 0 0 9 0 1 2 3 4 1 2 3 4 0 88 0 0 0 0 0 0 0 1 V 8157 0 0 2 5.89301e-315 0 0 7 Ground~ 168 95 269 0 1 3 0 2 0 0 0 53360 0 0 4 GND3 -14 -26 14 -18 0 4 GND; 0 0 0 0 3 0 1 1 0 0 0 0 0 1 0 0 0 3 GND 5572 0 0 2 39204.7 0 0 8 Tetrode~ 219 107 232 0 4 9 0 8 8 4 2 0 0 0 336 0 4 7695 26 -30 54 -22 2 V6 47 -26 61 -18 0 0 17 %D %1 %2 %3 %4 %S 0 0 0 9 0 1 2 3 4 1 2 3 4 0 88 0 0 0 0 0 0 0 1 V 8901 0 0 2 39204.7 1 0 9 V Source~ 197 200 33 0 2 5 0 7 8 0 0 0 16752 0 2 0V 15 -2 29 6 2 V5 15 -12 29 -4 0 0 11 %D %1 %2 %V 0 0 0 5 0 1 2 1 2 0 86 0 0 0 1 0 0 0 2 Vs 7361 0 0 2 39204.7 2 0 9 V Source~ 197 351 102 0 2 5 0 10 9 0 0 0 16752 0 2 0V 15 -2 29 6 2 V4 15 -12 29 -4 0 0 11 %D %1 %2 %V 0 0 0 5 0 1 2 1 2 0 86 0 0 0 1 0 0 0 2 Vs 4747 0 0 2 39204.7 3 0 2 +V 167 447 177 0 1 3 0 10 0 0 0 53744 0 4 130V -14 -23 14 -15 2 V3 15 -12 29 -4 0 0 13 %D %1 0 DC %V 0 0 0 3 0 1 1 0 86 0 0 0 1 0 0 0 1 V 972 0 0 2 39204.7 4 0 8 Tetrode~ 219 141 119 0 4 9 0 11 9 4 2 0 0 0 336 0 4 7695 26 -30 54 -22 2 V2 47 -26 61 -18 0 0 17 %D %1 %2 %3 %4 %S 0 0 0 9 0 1 2 3 4 1 2 3 4 0 88 0 0 0 0 0 0 0 1 V 3472 0 0 2 39204.7 5 0 7 Ground~ 168 62 126 0 1 3 0 2 0 0 0 53360 0 0 4 GND2 -14 -26 14 -18 0 4 GND; 0 0 0 0 3 0 1 1 0 0 0 0 0 1 0 0 0 3 GND 9998 0 0 2 39204.7 6 0 5 SAVE- 218 130 22 0 10 11 0 0 0 0 0 0 0 0 0 0 1 0 0 0 57552 0 1 A 3 -26 10 -18 0 0 0 14 *DC 6.65 153 0 0 0 0 1 0 0 0 0 0 0 1 0 0 0 4 SAVE 3536 0 0 2 39204.7 7 0 7 Ground~ 168 239 141 0 1 3 0 2 0 0 0 53360 0 0 0 0 4 GND; 0 0 0 0 3 0 1 1 0 0 0 0 0 1 0 0 0 3 GND 4597 0 0 2 39204.7 8 0 9 V Source~ 197 130 40 0 2 5 0 7 11 0 0 0 16752 0 2 0V 15 -2 29 6 2 V1 15 -12 29 -4 0 0 11 %D %1 %2 %V 0 0 0 5 0 1 2 1 2 0 86 0 0 0 1 0 0 0 2 Vs 3835 0 0 2 39204.7 9 0 9 V Source~ 197 239 95 0 2 5 0 7 2 0 0 0 17008 0 4 300V 9 -2 37 6 3 VDS 12 -12 33 -4 0 0 11 %D %1 %2 %V 0 0 0 5 0 1 2 1 2 0 86 0 0 0 1 0 0 0 2 Vs 3670 0 0 2 39204.7 10 0 9 V Source~ 197 64 72 0 2 5 0 4 2 0 0 0 17008 0 3 10V 12 -2 33 6 3 VGS 12 -12 33 -4 0 0 11 %D %1 %2 %V 0 0 0 5 0 1 2 1 2 0 86 0 0 0 1 0 0 0 2 Vs 5616 0 0 2 39204.7 11 0 7 Ground~ 168 128 167 0 1 3 0 2 0 0 0 53360 0 0 4 GND1 -14 -26 14 -18 0 4 GND; 0 0 0 0 3 0 1 1 0 0 0 0 0 1 0 0 0 3 GND 9323 0 0 2 39204.7 12 0 19 1 1 3 0 0 8320 0 1 3 0 0 3 715 51 715 50 661 50 3 0 4 0 0 16512 0 5 0 0 8 7 525 120 460 120 460 51 283 51 283 297 74 297 74 235 4 1 2 0 0 4096 0 5 2 0 0 2 540 140 540 156 2 2 5 0 0 4224 0 5 3 0 0 3 577 114 661 114 661 92 2 1 6 0 0 8320 0 4 5 0 0 3 550 72 551 72 551 91 1 0 7 0 0 4224 0 4 0 0 19 2 550 30 239 30 4 1 2 0 0 0 0 7 6 0 0 3 96 255 95 255 95 263 0 3 4 0 0 0 0 0 7 14 0 6 102 122 86 122 86 177 74 177 74 235 81 235 1 0 8 0 0 8192 0 7 0 0 10 3 107 206 107 191 200 191 2 2 8 0 0 4224 0 8 7 0 0 3 200 54 200 229 133 229 2 2 9 0 0 12416 0 11 9 0 0 5 167 116 184 116 184 198 351 198 351 123 1 0 7 0 0 0 0 8 0 0 19 2 200 12 200 12 1 1 10 0 0 8320 0 9 10 0 0 4 351 81 418 81 418 186 447 186 3 1 4 0 0 0 0 11 17 0 0 4 115 122 102 122 102 51 64 51 4 1 2 0 0 8192 0 11 18 0 0 3 130 142 128 142 128 161 2 1 11 0 0 4224 0 15 11 0 0 4 130 61 130 79 141 79 141 93 2 1 2 0 0 8320 0 17 12 0 0 3 64 93 62 93 62 120 2 1 2 0 0 0 0 16 14 0 0 2 239 116 239 135 1 1 7 0 0 0 0 15 16 0 0 4 130 19 130 12 239 12 239 74 0 0 4 0 0 0 0 3 VDS 0 200 1 3 VGS 0 -20 -5 3 0 1 4 0 5e-05 2.5e-08 2.5e-08 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 5 -1 10 10 10 0 10 10 0 2992 2259520 100 229 0 0 77 66 617 396 0 97 640 568 617 66 77 66 617 66 617 396 0 0 0 0 0 0 0 0 12401 0 4 50 200 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 |
#10 |
Ummm..., do we need ALL those numbers?
rp = (del Vp / del Ip) = Mu/gm = 2 Mu/ ( 3G (Vp/Mu + Vg)^.5) = 2 MU/(3 G^.6666 Ip^.3333) I think you just have to put the tube data for your selected operating point into the above mentioned G formula. Mysterious # is then 1/G. Don
Ohms Law V = I R |
| CircuitMaker | loovet | Pass Labs | 2 | 1st December 2003 08:53 PM |
| SPICE Question. | sam9 | Solid State | 0 | 21st June 2003 09:53 PM |
| Another Spice Question | RobPhill33 | Everything Else | 0 | 3rd March 2003 01:56 AM |
| Spice models for circuitmaker | ashok | Tubes / Valves | 5 | 8th February 2003 08:33 AM |
| Spice Model question | Ian Macmillan | Solid State | 3 | 5th July 2002 09:36 AM |
| Page generated in 0.14459 seconds (86.75% PHP - 13.25% MySQL) with 10 queries |
