| diyAudio Sponsor | ||
How do I calculate the output impedance of my PSU?
I have a 5AR4 into a CLCLC filter. If I model it in PSUD, can I determine the output impedance by varying the current draw by 1mA, and note the step difference in voltage that results? By that method, I currently get an impedance of around 2500 ohms. By varying the capacitance in each of the stages, I can certainly reduce the voltage drop change. Is this the best way to lower the impedance? P.S. I just added some series resistance to the PSU to reduce the Q factor and stop some low frequency motorboating. The motorboating is gone, but it doesn't sound as dynamic anymore.... |
#2 |
LC filter's output impedance is high. I think that you're ready to talk about regulation !!
Mic |
| How to calculate gain and output impedance? | RogerGustavsson | Solid State | 1 | 7th June 2008 05:09 PM |
| How to calculate Tube Preamp output impedance? | john65b | Tubes / Valves | 20 | 20th November 2007 02:44 PM |
| The rule to calculate the load impedance of two or more valvces connected in parallel | Antonio Tucci | Tubes / Valves | 16 | 7th February 2004 03:49 PM |
| Formula to calculate speaker impedance | Perry Babin | Multi-Way | 5 | 21st November 2003 06:19 AM |
| How do I calculate (or measure) my amp's output impedance? | Saurav | Tubes / Valves | 22 | 27th September 2003 03:55 AM |
| Page generated in 0.07896 seconds (77.91% PHP - 22.09% MySQL) with 10 queries |
