Got your Email about the 6080 amp. Your email address keeps bouncing.
Heres the message I tried to send;
Hi Albert,
I made one or two changes to the amp recently. I will knock up a new schematic
for you and send it. Its now simpler and better with the magic differential
output stage at the end.
The power supply is a little tricky because I used a big salvaged PA toroidal
which gave me 62-0-62V AC. This is not a standard transformer spec. The
nearest generally availble would be 55-0-55V AC which will give you about 10V
less DC. Since the power supply is on the edge of what is neccessary this is
an issue which could cause problems.
I will be back in touch in a few days with the schematic.
Shoog
Hi Albert,
Shoog
