| diyAudio Sponsor | ||
#1 | |
I was looking at the James Transformers at Euphonia Audio and was going to buy a pair of the 6113HS (3.5K/5K, 10W Orient HiB), but they are sold out.
However they have another one (6112HS 2.5K/3.5K, 10W Orient HiB) still in stock. I need a 5K primary for the amp I'm building and Euphonia's web site says I can use the 4 Ohm secondary instead: Quote:
Thanks |
#2 |
Technically, you can do it, but it most likely will not sound as good. A 5k primary will need twice as much inductance as a 2.5k primary for any given low frequency cut off point. Basically what I am saying is that the 2.5k unit used as 5k will not give the low end response as good as the 5k unit.
Be patient and wait for the real deal. Or change your operating point so you can use a 2.5k primary. But this probably will not sound as good either. Daniel |
#3 |
Thanks for the information. I figured there had to be a draw back.
| Quick transformer question | Brit01 | Tubes / Valves | 5 | 23rd July 2009 07:26 PM |
| Another quick transformer question | Hiwatt25 | Chip Amps | 6 | 8th February 2008 10:56 AM |
| Quick Output Transformer Question | dsavitsk | Tubes / Valves | 5 | 20th April 2006 07:08 AM |
| Quick LM4780 Transformer Question | dfdye | Chip Amps | 4 | 16th December 2005 07:46 PM |
| quick transformer question | VictorG | Tubes / Valves | 2 | 9th January 2004 09:00 PM |
| Page generated in 0.07221 seconds (70.34% PHP - 29.66% MySQL) with 10 queries |
