Questions about a choke Questions about a choke - Page 2 - diyAudio
Old 22nd January 2003, 11:19 PM   #11
Gabevee is offline Gabevee
Gabevee's Avatar
The cathode is at 5V. Remember, it IS the heater.
On the negative half of the cycle, the plate is negative - the electrons don't go to it. On the positive half, it's positive - the electrons go to it. That's all there is to it.
Re. the 5volt thing... what???????? With regards the primary voltage of the transformer, the heater voltage is of no consequence.
Re. the plate being negative etc.... what did I say that made what you are saying here any different?? We seem to be in agreement there.
What I am clarifying to Tony is that with respects the plate, the cathode is negative so conduction will occur, because it sees negative through the load.
Conversely, the load sees a positive potential at the cathode when it is conducting.
That is all there is to that.
Gabe
Gabe CGV Electronics
Home of the CGV-300B amplifier on a budget
Questions about a chokeHide this!Advertise here!
Basic choke quality/sonic benefit questions phrarod Tubes / Valves 1 17th July 2009 06:37 PM
Choke input LC chain questions..Q?, minload? Richard Ellis Tubes / Valves 1 30th June 2009 02:20 AM
Choke Design - Basic Questions poynton Tubes / Valves 3 19th February 2008 02:07 AM
Choke rating for choke input duty cbutterworth Tubes / Valves 14 9th November 2007 04:43 PM
Swinging Choke or Smoothing Choke danFrank Tubes / Valves 4 11th February 2007 11:05 AM
Copyright ©1999-2017 diyAudio
