Tube sockets without the ceramic carrier.
Old 16th May 2007, 06:20 AM   #1
ashok is offline ashok
ashok's Avatar
Default Tube sockets without the ceramic carrier.
Does anyone sell tube sockets without the ceramic or plastic carrier? I couldn't find it in a search.
I mean just the metal part of the socket that will solder directly to a pcb independent of each other. So there will be a ring of pins sticking out of the pcb. I vaguely remember seeing a picture somewhere but I can't be sure.
Cheers.
AM
Old 16th May 2007, 06:56 AM   #2
jarthel is offline jarthel  Australia
why not just buy a socket and break the ceramic?
they are very easy to break. and with care, you can avoid damaging the pin sockets.
Old 16th May 2007, 07:13 AM   #3
Geek is offline Geek
Geek's Avatar
You want individual I.C. or header pin sockets of appropriate size. Seen that a few times for oddball tubes, like 10-pin minatures or nixies in PCB's. IIRC, Motorola was the first to start the trend.
Cheers!
Old 16th May 2007, 07:15 AM   #4
ashok's Avatar
The metal part of the ceramic sockets are not very good as they are made of folded metal sheet.
I wanted machined sockets like what you find in machined IC sockets but larger.
AM
Old 16th May 2007, 07:43 AM   #5
wrenchone is offline wrenchone  United States
wrenchone's Avatar
You can find appropriate pin sockets made by Mill-Max from either Digi-Key or Mouser. Choose the socket size based on the pin diameter of the tube in question. Also, an open-ended sockt would probably be best, so you can snug those tubes right down in the socket without bottoming out the pins.
Old 16th May 2007, 08:24 AM   #6
Simpleton is offline Simpleton  Portugal
Get a DB-25 male plug and take the metallic sockets out, they fit nicelly on noval and similar size pins.
"There's something organic about a happy cloud of electrons" - Neutron Bob
Tube sockets without the ceramic carrier.Hide this!Advertise here!
For Sale: Ceramic 9 pin tube sockets $1.00 each 12 for $10.00 Sal Brisindi Swap Meet 0 26th June 2007 11:45 PM
Bit of Ceramic Tube FR Fun optic Full Range 9 27th April 2007 12:17 AM
Looking for tube sockets satelitis Tubes / Valves 0 8th May 2006 02:08 PM
Tube Sockets FrankRoss Tubes / Valves 4 19th March 2004 11:48 PM
