Very high plate voltage EL34 amp - diyAudio
Old 15th May 2007, 06:30 AM   #1
Boris_The_Blade's Avatar
Default Very high plate voltage EL34 amp
Does anyone know of any amps or has anyone ever built an amp that uses excessive plate voltage on new production EL34's? I am converting an amp that supplies 680V plates and 335V for screens. I plan to use a quad of them in pentode per channel with a load of 4.5k-6k ohm, but I'm concerned if the (new production) tubes can take it, and also if they will sound OK running at such low current.
thanks,
Old 16th May 2007, 02:43 AM   #2
Nobody has any insight? Anybody ever use or build an amp with over 600V plates for new production EL34s? I was looking to use JJ/Tesla...anybody know if they can handle it?
Old 16th May 2007, 03:49 AM   #3
They claim they can.
http://www.jj-electronic.sk//pdf/E34L.pdf
I've run them up to 500V in triode mode which exceeds its g2 rating without any smoke or flames.
Ian
Old 16th May 2007, 05:19 AM   #4
Ya know, I just thought of this -- BOI audioworks can match a set for a requested operating point. So, you could tell them you want to run them at 680V plate / 330V screen / I mA idle current (keep it within reasonable plate dissipation limits, of course), and they should be able to set you up with a couple quads tested for that voltage.
They've hooked me up with two very-well-matched quads of KT66s that I basically requested for use at max plate dissipation
EL34, KT88, High Voltage?, VTL.. kegger Tubes / Valves 28 18th August 2015 07:25 AM
Plate Current VS Plate Voltage Graphs Captn Dave Tubes / Valves 2 13th February 2009 08:57 PM
Why does 6BM8 have so high max plate voltage? vax9000 Tubes / Valves 2 3rd September 2007 06:46 PM
Why such high plate voltage in 2A3 DRD? G Tubes / Valves 2 16th January 2007 02:10 AM
Typical plate Voltage for el34 rmarchand98119 Tubes / Valves 7 5th July 2006 11:43 PM
Copyright 1999-2017 diyAudio
