diyAudio Sponsor
Old 14th May 2007, 05:52 PM   #1
dsavitsk's Avatar
Default Derive Triode Curves from Pentode Curves?
Is it possible to derive at least a reasonable approximation of how a pentode will behave triode strapped from the pentode curves? Being exact is not necessary, but just getting a sense of ra, gm, and mu at some point would be great. Any tricks to doing this?
http://www.ecpaudio.com
Old 14th May 2007, 06:04 PM   #2
rdf is offline rdf  Canada
rdf's Avatar
Pentode data sheets normally contain multiple plate curves representing different screen voltages. Graph the operating points where Vp = Vg2.
Blame the Manichaeists
Old 14th May 2007, 06:59 PM   #3
ilimzn is offline ilimzn  Croatia
Exactly what rdf said - unfortunately, if you are lucky, you will have about 3 points per grid voltage line (most pentode datasheets have a set of curves for two or three screen grid voltages) which can give you a crude idea of what the triode curves will be (most screen grid voltages will be outside the values you'll want to use on the trioded 'plate' and if there are no screen current graphs, you are out of luck - remember that trioded 'plate' current equals pentode plate + screen current)...
Old 14th May 2007, 07:10 PM   #4
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Default Good enough for jazz...
Most pentode data sheets give a value for the amplification factor from g1 to g2. If you were to pick a true triode with similar anode dissipation and cathode current ratings and a similar mu to your triode-strapped pentode, I doubt if you would be very far wrong.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
814 triode curves ailouros6 Tubes / Valves 9 29th April 2009 06:04 PM
4-65A Triode curves? dshortt9 Tubes / Valves 24 15th January 2008 05:27 PM
Wanted Triode strapped curves for pentode of ECL82. Shoog Tubes / Valves 2 28th March 2007 09:03 PM
type 40 triode curves abj1 Tubes / Valves 2 6th February 2007 04:02 AM
Measuring Triode-Connected Pentode Curves rdf Tubes / Valves 23 11th April 2006 10:29 PM
Page generated in 0.08548 seconds (69.19% PHP - 30.81% MySQL) with 10 queries
