from old " Vintage audio trader" site :
"..........MI-11401. Anybody have a real picture? I had to "
retouch " my bad photo-copies with ink, they were
so faint. These are not really very accurate in
terms of tone contrast, especially the furnace;
Only the top " band ' is dark gray, the rest is light
umber gray. The grill was brushed-satin chrome
The other cabinet is an illustration from an article by H.F. Olson and A.R. Morgan of RCA
laboratories from a 1950 (? ) Issue of Radio and Television News; A High Quality SOUND SYSTEM For the Home. Shown is the original LC1A, with smooth cone ( MI-11411 ). Also, the amplifier he designed to be part of the system. The first 45 rpm record changer is part of the system as well. This is a great article, in which he gives plans and instructions on building the cabinet AND a no- negative-feedback, directly-heated triode amp using one 6J5, one 6SN7, four 6F6 tubes and a 5Y3 rectifier in the power supply. A ten watt amp maybe. In RCA's Living Room Laboratory, sound levels averaging 80 dB were achieved with approximatly 0.050 watt input power. This means low power all triode amplification was more than sufficient. Olson states in the article that they were surprised to determine that a 1/4 to 1/2 watt
amplifier would give satisfactory results in the average room. 2 or 3 per cent distortion from the Amp at 90 dB did not bother him. Not from no feedback triodes. They sound sweet! "
I need any info regarding those amps............
schematic and few free OPT's will be perfect ........
ps. even if I can't find any DHT in list of mentioned toobz .........
The second amp you speak of is listed here I do believe
http://www.bonavolta.ch/hobby/en/audio/6f6.htm
Been building mine off and on for alomost a year now
Dan_Steele said:The second amp you speak of is listed here I do believe
No worries dude,
Richard sherman of http://www.shermanaudio.com has also built his own named the Aurora and is of great help (he inspired me to start mine) he has a section about it on his website,
Its worth noting that the voltage stated 390v X 2 is to much for the 6f6g's I have mine running around 280ish.
