diyAudio Sponsor
Old 15th May 2007, 09:37 PM   #21
2wo is offline 2wo  United States
Remember, some of the chokes and large caps can mount to the wood frame…John
Old 15th May 2007, 11:38 PM   #22
Kofi Annan's Avatar
OK-- last go 'round, I hope.
I'm trying to leverage aesthetics with a desire for a short signal / wiring path, so I did as suggested with the cap-n-rectifier swap, but I couldn't quite realize the center-of-the-amp presentation for the OPT and 300b.
Anyway, I think this marries a reasonably good look with an allowance for a short wiring path. As long as everthing looks hunky dory with the transformer orientation, I think this will work.
Have a look:
Old 15th May 2007, 11:40 PM   #23
Kofi Annan's Avatar
Now a long view of the guts. In this one, it's easy to see the transformers mounted on the wood frame as you suggested, John.
Old 15th May 2007, 11:41 PM   #24
Kofi Annan's Avatar
An of course, the top view.
Old 16th May 2007, 12:51 AM   #25
Sheldon is offline Sheldon  United States
Now for some fun, do a mirror for the other channel.
Sheldon
Old 16th May 2007, 01:09 AM   #26
garbage is offline garbage  Singapore
garbage's Avatar
you might want to check out my version of the d3a/300b drd build at my picasa web album.
Old 16th May 2007, 01:28 AM   #27
Kofi Annan's Avatar
Sheldon
Zzzzzzzzzzzing!
Old 16th May 2007, 01:29 AM   #28
Kofi Annan's Avatar
Zzzzzzzzzzzzzzang!
Man, Google Sketchup is the greatest. Even Kofi can do it.
Kofi
Old 16th May 2007, 01:33 AM   #29
Kofi Annan's Avatar
Will do! Thanks!
Kofi
Old 17th May 2007, 01:38 AM   #30
Kofi Annan's Avatar
So, a representation of my DIYAudio conscience told me that I'd better stick with the common-mode choke. Any ideas on where a cheaper 20H (or thereabouts) CMC could be found?
Kofi
Kofi Annan in: "Cascodin' with Steve Bench's RIAA!" Kofi Annan Tubes / Valves 261 10th June 2011 05:48 PM
Kofi Annan in: "Kofi's Living Room" Kofi Annan Full Range 5 25th May 2008 05:19 PM
Kofi Annan in: "300beee!" or "Kofi Gets a Toy" Kofi Annan Tubes / Valves 125 25th August 2006 03:39 AM
Page generated in 0.11012 seconds (77.25% PHP - 22.75% MySQL) with 11 queries
