diyAudio Sponsor
Old 14th October 2007, 04:14 PM   #131
Kofi Annan's Avatar
OK-- so I installed the Lundahl common-mode chokes and had a listen. The sound was very different-- softer with not as much gain. So, I figure it's a voltage problem, right?
I had to readjust the trimpot to lower the d3A anode / 300b grid voltage to about 177V (it was about 205V after the choke install) and things seemed about normal, but now the B+ is too high-- the 300b is seeing 375V instead of 350V, which I'm concerned is too high.
Also, the 1K cathode resistor (which measures .995K) is dropping 68.5V, which means it's passing almost 69mA of current.
I'm still taking some measurements, but it seems that the additional B+ is causing some problems. I may need to add a resistor in series with the B+ to drop some voltage, right?
Any suggestions?
Kofi
Old 14th October 2007, 04:26 PM   #132
Kofi Annan's Avatar
Oh, and the B+ is now at 660V. It's pretty surprising to me that changing the choke would do this.
Still investigating...
Kofi
Old 14th October 2007, 04:52 PM   #133
Sheldon is offline Sheldon  United States
At the risk of sounding like a broken record, it would be most instructive to show us your schematic with all the actual node voltages indicated. Before and after would be even better. Here's an example:
http://www.diyaudio.com/forums/showt...65#post1322965
Meantime, the voltage changes you see are not necessarily alarming. The new choke might have much lower DCR, but without the whole picture?
Sheldon
Old 14th October 2007, 05:15 PM   #134
Kofi Annan's Avatar
Here you go. The bolded figures that don't have a "V" after them are my measured voltages.
Still puzzled as to why it looks like I'm running at 69mA, though.
Anything jump out at you as particularly fishy here?
Thanks for your help.
Kofi
File Type: gif drdamp with voltages (after lundahl).gif (34.7 KB, 276 views)
Old 14th October 2007, 06:22 PM   #135
Looks fine to me Kofi. The bias current is as you calculated. I don't know what the dissapation limit you want on the output tube, but based on a cursory check, it seems you are well within the ratings. But double check that.
If you want to lower the current, you have several options. Easiest is to adjust the voltage at the grid with your lower pot. Or you can increase the other resistor values in series with the 300b cathode. I'd try the simple adjustment first. Then look at the curves for the input tube to make sure you are still in a nice linear region. And listen.
These kind of designs are a bit tricky because all the voltages are interdependent. But as long as you are in safe dissapation areas, play at will.
If you want to reduce ps voltage, I wouldn't use series resistance . A much better approach would be to reduce the size of the power supply input cap.
Sheldon
Old 15th October 2007, 06:15 AM   #136
Kofi,
Its a tube amp - that means +/- 20% on voltages - those voltage readings are fine.
Quick Calcs:
265-197 V across that 1K in the cathode.
That means 68mA and therefore also -68V bias from grid to cathode
644 - 265 = 379 V Anode to Cathode.
At 68mA that gives 25.8W Anode dissipation - a good conservative place to run the 300B.
Extrapolating off the 300B data sheet that operating point should be giving you about 8 watts of audio out.
Unless you are somehow unhappy with the sound I'd say its finished - sit back and enjoy.
Ian
Kofi Annan in: "Cascodin' with Steve Bench's RIAA!" Kofi Annan Tubes / Valves 261 10th June 2011 05:48 PM
Kofi Annan in: "Kofi's Living Room" Kofi Annan Full Range 5 25th May 2008 05:19 PM
Kofi Annan in: "300beee!" or "Kofi Gets a Toy" Kofi Annan Tubes / Valves 125 25th August 2006 03:39 AM
Page generated in 0.08670 seconds (75.99% PHP - 24.01% MySQL) with 11 queries
