how do you know you need matched pair? how do you know you need matched pair? - diyAudio
Old 11th May 2007, 01:05 AM   #1
jarthel is offline jarthel  Australia
Default how do you know you need matched pair?
I have recently built an aikido headphone amp and I'm wondering what are the criteria that determines the need for matched pairs.
not just for the aikido but other designs like PP or SE or PSE.
thank you.
Old 11th May 2007, 02:45 PM   #2
Shoog is offline Shoog
Shoog's Avatar
In PP it will help because it will reduce standing DC in the transformer, which will allow the transformer to deliver better bass.
In all other applications (apart from possibly LTP phase splitting) it marketing driven and a complete waist of money.
Remember your expensive matched pair will stay matched for less than 50% of their life- are you going to bin them after that.
I think using valves from the same batch and changing valves at the same time is more than adequate.
Shoog
Old 11th May 2007, 02:56 PM   #3
rdf is offline rdf  Canada
rdf's Avatar
Simple zero feedback topologies also require well matched tubes for channel balance. The second option is to have plenty of spares and keep swapping until the cumulative gain errors in the circuit cancel to an acceptable degree.
Old 11th May 2007, 03:02 PM   #4
Shoog's Avatar
Have you noticed this as a practical issue ?
Balance control might be a cheaper solution.
Shoog
Old 11th May 2007, 03:57 PM   #5
rdf's Avatar
Surprisingly yes. Quite often just swapping drivers between channels gets it close enough.
how do you know you need matched pair?Hide this!Advertise here!
FS: Accuton C44-8 (matched pair) dsrviola Swap Meet 6 19th April 2009 06:13 PM
FT/FS: EH 6CA7 Matched Pair Zap Swap Meet 2 10th November 2008 12:50 AM
Need matched pair STW34NB20. Colescuttle Swap Meet 7 26th July 2008 08:03 PM
FS: Matched pair NOS CEI 2C51 cartman Swap Meet 0 10th December 2007 08:07 AM
i have a matched pair of 3cx1000a7.. Mr. Triatic Tubes / Valves 8 4th October 2004 08:29 PM
Copyright ©1999-2017 diyAudio
