| diyAudio Sponsor | ||
Hi all-
I'm working on a nice Zenith radio that has a push pull output stage, and had a question. This output stage does not have a phase inverter tube, instead phase inversion is accomplished by a transformer. My question is, do the output tubes have to be matched for current draw in this type of output stage? I've never seen this type of output before, so I'm not sure about tube matching. Thanks Glenn
"Imagination is more important than knowledge" |
#2 |
It just a normal output stage with an interstage phase splitting transformer (should sound nice). The output transformer should have a slight gap to allow for slight current mismatch. This is standard for almost all PP output stages. The interstage transformer is designed like a SE output transformer ie with a suitable airgap.
Shoog |
#3 |
Thanks Shoog.
The only reason I ask is that this set has one original 6L6 with the "ST" shape, and the other is a newer (still a vintage '70's tube) 6L6GC with the small cylindrical round top envelope. I guess this doesn't matter as long as the current draw is close. I just didn't want to ruin the set by running it with possibly mis-matched tubes. I'm still looking for a vintage "ST" shaped 6L6, as the newer looking units don't look right in this radio. Glenn The two upper left tubes are the 6L6's. Guess which one is not original
#4 |
Looks lovely - good luck with it.
Shoog |
| Matched tubes or not matched | hilbert_mostert | Tubes / Valves | 29 | 27th March 2009 10:13 PM |
| New matched tubes - where to use them | mt1962 | Tubes / Valves | 2 | 27th October 2008 12:08 AM |
| matched tubes? | webelo | Tubes / Valves | 6 | 16th December 2007 10:57 PM |
| do pp output tubes have to be matched? | 9am53 | Tubes / Valves | 12 | 17th March 2005 09:01 PM |
| Four matched 11MS8 tubes - all RAYTHEON | percy | Swap Meet | 0 | 25th October 2004 04:51 PM |
| Page generated in 0.07055 seconds (72.96% PHP - 27.04% MySQL) with 10 queries |
