diyAudio Sponsor
Old 10th May 2007, 12:04 PM   #1
croccodillo's Avatar
Default GU-50 output trafo
Hi all,
I read everything I found about GU-50 tubes, here on the forum and on the net (I'm thinking to use them for my new amplifier).
The problem is that it is not clear to me the actual outrput impedance of such a tube: I found reference to a 10K, 5K, 2K transformers, and I don't know which is the right value.
The datasheet I found do not report any value for the output impedance, nor any graph for triode-strapped condition.
Can you help me?
Thanks in advance,
Giovanni
In Nomine Libertatis Vincula Edificamus,
In Nomine Veritatis Mendacia Efferimus.
Old 10th May 2007, 06:43 PM   #2
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
What topology are you planning on using them in?
Old 10th May 2007, 06:49 PM   #3
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Hi Giovanni!
For pentodes (regulated G2):
GU-50 100W output and power transformers
For triodes with 400V plate voltage you'll probably need 2-3K CT
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 11th May 2007, 07:09 AM   #4
Tweeker is offline Tweeker  United States
Triode curves.
Be sure your foil hat has a good low impedance ground.
Old 11th May 2007, 07:22 AM   #5
Hi, thanks for the answer.
The topology will be a parafeed SE amplifier.
I would like to use two or more paralleled GU-50 as output tube, driven with a High Voltage CCS (not decided yet if use a solid state one or a tube one).
Output trafo will be a toroid (I found a good -and cheap- manufacturer here in Italy).
THIS is a draft of the idea I have.
The output tubes will have an idle voltage of about 300V (low, I know), while the CCS will work between 200 and 0V, with a current of 100mA.
I'm thinking to use two paralleled GU-50 tubes also for the upper CCS.
If I can keep the output impedance as low as 1K, I can have about 20W of RMS output power...
I don't know if use the GU-50 in pentode mode, triode-strapped mode, enhanced triode or whatever else comibnation of grid1, 2, 3 voltages...
My idea was to use them as triode as output tubes, and use pentode mode (if I will ever use tubes) for the CCS.
Ciao,
Giovanni
Old 11th May 2007, 07:31 AM   #6
Boeing is offline Boeing  Japan
Hi ! I am using my GU 50 SE tube amp with 3.5KOhm OPT, at 330V plate voltage. It sounds beautiful .
Regards.
Old 11th May 2007, 07:37 AM   #7
Thanks boeing for the feedback; some more information?
Do you use a single tube? How is it connected (triode, pentode, what else)?
Ciao,
Giovanni
Old 11th May 2007, 08:55 AM   #8
Hi Croccodillo ! My tube amp is triod connection. My OPT has Ultra linner terminal, but I have never tried it.
Regards.
VALVOLOZZO triode amp with toroids output trafo...help me zig290682 Tubes / Valves 14 11th June 2009 06:50 PM
Got a big output trafo I want to use. lawbadman Tubes / Valves 27 29th October 2008 04:14 PM
Output trafo for WE-91 L'Audiophile amp? WE91 Tubes / Valves 81 19th March 2007 11:34 AM
PP Output Trafo Measurement jkeny Tubes / Valves 8 6th February 2007 08:29 AM
Page generated in 0.09282 seconds (76.65% PHP - 23.35% MySQL) with 11 queries
