| diyAudio Sponsor | ||
Hey,
Just wondering as i carnt find anything on the search. Is there any difference using a toroidal transformer compared to the normal type seen on most of the designs? Regards Damon |
#2 |
Hi Damon,
which duty are you refering to - power transformer or output transformer? Regards, Tom
If in doubt, just measure. |
#3 |
Either?
Got some experience of winding transformers but was just wondering out of intrest. Damon |
#4 |
In power transformer duty a toroidal will allow much more high frequency hash. In this case it will perform worse in terms of audio than an EI transformer. However they are more compact and efficient.
For output duty the toroidal will have better bandwidth than a comparable EI transformer. However in PP duty it will not tolarate any DC between the sides or it will saturate. This can be compensated for in the circuit design. In a SE design they need to be used as parafeed transformers, ie no DC in the transformer. Piltron do a range of toroidal output transformers which have air gaps incorporated. These allow them to be used with current unbalanced PP stages, and as SE transformers. Shoog |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 10:44 AM |
| FS: Transformers | alexcd | Swap Meet | 0 | 19th November 2008 08:34 PM |
| WTB : Transformers | korben69 | Swap Meet | 1 | 27th June 2008 06:05 PM |
| my first amp (transformers???) | fitchmicah | Chip Amps | 5 | 7th January 2007 07:26 PM |
| Back to Back transformers as Isolation transformers | mikee55 | Chip Amps | 2 | 17th March 2006 11:38 AM |
| Page generated in 0.07614 seconds (71.19% PHP - 28.81% MySQL) with 10 queries |
