| diyAudio Sponsor | ||
I downloaded a spice model for a 6AV5 off the web somewhere. This was late last year. It was lost when my old computer died. I can not find it anywhere now. Does anyone have a copy of it, or know where it can be found.
Spice models for any other sweep tubes would also be useful.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#2 |
Hi Tubelab,
Here's my whole collection. Cheers! |
#3 |
Another spice model
Lately I ran across the specs for the 7695 tube, which also has a 50V at 150ma heater, but can do about 4 watts out, instead of about 1 2/3 watts from a 50C5. The 7754 is the 6.3V version. It's load would be 1100 ohms instead of 2.5K. Rp=7K, gm=11000umhos, G1 voltage=-11V, G2=130V, plate current 100ma. I haven't obtained any of these tubes, but they do look interesting. They are physically fatter, regular 9 pin miniature tube socket but wide body (like a compactron they made with a regular 9 pin pattern). I'd have to change the OPTs though. Here's a 3f4 spice model: *Vacuum Tube Tetrode (Audio freq.) .SUBCKT X7695 A S G K * * Calculate contribution to cathode current * *the number at the right end determines sharpness of knee Bat at 0 V=0.636*ATAN(V(A,K)/9) Bgsg gsg 0 V=URAMP(V(S,K)*0.12-((-V(G,K))*0.68)+V(A,K)/290) Bgss gss 0 V=URAMP(V(S,K)*0.12-((-V(G,K))*0.87)+V(A,K)/290) Bgsg2 gsg2 0 V=V(gsg)^1.35 Bgss2 gss2 0 V=V(gss)^1.35 Bcath cc 0 V=V(gsg2)*V(at) * * Calculate anode current, grid line spacing adjust and peak plate current * Ba A K I=6.260E-3*V(cc) * * Calculate screen current * Bscrn sc 0 V=V(gss2)*(1.1-V(at)) Bs S K I=2.46E-3*V(sc) * * Grid current (approximation - does not model low va/vs) * Bg G K I=(URAMP(V(G,K)+1)^1.5)*50E-6 * * Capacitances * Cg1 G K 10p Cak A K 9p Cg1a G A 0.75p .ENDS X7695 |
#4 |
Geek:
Thanks, the spice.txt file looks like the one that I had. I have a few ideas to extreme to try in the real world, until they work in the virtual world. WA2ISE: The 7695 sounds interesting, I don't think that I have any of them, but I do have some other "fat boy" 9 pin tubes. I can't find the numbers right now but I remember a video output tube and a dual dissimilar triode for vertical output service. Thanks for the model, if I make something in the virtual world, I guess I will have to find some of the tubes.
| Help With 6v6 Spice Model | porcatroya | Tubes / Valves | 0 | 5th May 2008 07:41 AM |
| SPICE model | Prune | Parts | 6 | 16th October 2004 04:22 PM |
| Spice Model 6CW4 | UltimateX86 | Tubes / Valves | 6 | 23rd September 2004 09:10 AM |
| Spice model | doigtee | Tubes / Valves | 6 | 12th July 2003 12:42 PM |
| Spice model for LED? | G | Solid State | 5 | 14th September 2002 04:33 AM |
| Page generated in 0.08153 seconds (73.11% PHP - 26.89% MySQL) with 11 queries |
