diyAudio Sponsor
Old 9th May 2007, 10:23 PM   #1
Sandor is offline Sandor  Italy
Default Audio Research LS2 from 110V to 220V
Hello,
I have to modify an Audio Research LS2 preamp, which accepts a 110Vac mains supply, so that It accepts a 230V power.
Does anyone know the technical specifications of the two mains transformers, so that I can substitute them?
Regards.
Paul
Old 9th May 2007, 11:25 PM   #2
Paul,
1st check for dual primary power trafos. In that happy situation, simply rewire from parallel to series.
If dual primaries are not present. Buy a "230/115" VAC autotransformer of appropriate VA rating. You'll spend LESS and get going much more quickly.
Eli D.
Old 11th May 2007, 05:34 PM   #3
Thank you, Eli, I'll try to apply your suggestions.
Paul
110v or 220v, how can you tell? fjmart134 Tubes / Valves 2 8th June 2009 10:18 PM
Solid State 110V to 220V transformer affects audio? Frosti Solid State 8 4th May 2009 07:39 AM
AR XA 220V to 110V dan duette Analogue Source 2 13th February 2009 01:08 PM
How to convert 220V to 110V??? Real Prober Digital Source 4 5th November 2004 07:02 AM
Help: conversion from 110v to 220v Russell Sit Solid State 13 5th December 2002 08:28 AM
Page generated in 0.06446 seconds (67.69% PHP - 32.31% MySQL) with 10 queries
